Lexus IS200 engine swap
drift_bear
Is that for a 2JZ into an IS200 dude?
I wouldn't mind having another lexus as it was a good car and great fun to drive, just lacked decent power level compared to the supe
/QUOTE]
Lexus IS 300 has a 2JZ motor but NA I would presume the sump etc are from a GS300 but it will all just bolt in, IS300's are all auto (IS200 and 300 are same shell BTW)
If the NA would drop straight in, then how can't a TT? Is the W154 not weaker than the lexus 6 speed box?
I'm just wanting to find out all the info I would need if I wanted to go down this route and find somewhere that would take on the challenge with a rough price.
The Lexus manual box is the same as the S15 Silvia IIRC, which means its useless for tuning.
You need the sumps and maybe mounts from a GS300/IS300 the box and prob may well slot straight in but some wiring to get the ecu in.
Thanks dude! Cab you pm me a price if i was to provide you with an is300 and the tt engine and box.
will the drive shaft, diff etc on an is300 be ok with the extra power from a 2jz gte engine?
  • 2 weeks later...
