bedlam Posted July 27, 2005 Share Posted July 27, 2005 Ok Hope some of you more techy people on here might be able to help me out with a problem my autobox seems to have develpoed.. Car is a Soarer TT...with the vortex single kit on it..and full emange setup..and is running 430bhp+. Now the autobox seems to be having a little problem..in that it now likes to change around 7,500/7,800, when we blat the car along our private road. Now we have just changed all fluids and i mean change complete flush in the box. The box is silky smooth driving normal..and if i accelerate hard and just ease of the pedal the box will change fine. If i do a 1/4 mile start..ie..hold brake on left foot and take revs to 2,800, then the car pulls like mad but the box is changing way up to high. Now it seems the box is pulling the timing cause it sees the revs are to high...and the car aint playing nice. So any help on this prob would be well appreciated Cheers Andy Quote Link to comment Share on other sites More sharing options...
bedlam Posted July 28, 2005 Author Share Posted July 28, 2005 Update Well it looks like the box is knackered..as i have checked the fluid level and it is fine, it selects forward gears fine and drives ok, but when i select reverse, the car goes into reverse fine but wont reverse at any speed 3,000rpm and the car just trundles back slowly. So would i be right in saying the box is kaput . Andy Quote Link to comment Share on other sites More sharing options...
Steve Posted July 30, 2005 Share Posted July 30, 2005 Dont know about the autos mate, but hope you get it sorted! Quote Link to comment Share on other sites More sharing options...
JustGav Posted July 30, 2005 Share Posted July 30, 2005 Hmmm I've got the same issue with my box at the moment... Reverse works when it is cold, but not when it is warm... Also seems to rev damn high, going to check the wiring harness today to make sure it isn't related to that... Gav Quote Link to comment Share on other sites More sharing options...
bedlam Posted July 30, 2005 Author Share Posted July 30, 2005 Ok Smarty thanks for the good wishes mate . Gaz I really DO hope your not having the exact same prob as ours. As our box was well fecked the bands where worn badly which is the reason your car is revving so high as the torque converter is spinning up to much. We have not fitted another box and the car is perfect now..change is spot on. Best of luck with yuor car gaz. Andy PS thats a sure sign the box is on it's way out when reverse goes . Quote Link to comment Share on other sites More sharing options...
