JMB Posted February 1, 2012 Share Posted February 1, 2012 Hi, I got those spark plug : BKR5EIX-11 5464, is it good for my car ? By the way, as my car is 104000km, should I change the ignition coils and / or ignition wires ? Thanks, Link to comment Share on other sites More sharing options...
Nic Posted February 1, 2012 Share Posted February 1, 2012 VVTi TT Supra? What boost are you running? If they haven't been changed already then I would fit new coil pack connectors as these become brittle over time and break, see how to guideHERE. No reason to change the coil packs unless they are faulty. There are no HT leads, the coil packs connect directly to the wiring loom. If you are fitting new plugs I'd also replace the 2 x cam cover breather hoses - remove the plastic engine cover and you'll see them - as these also become brittle and can easily split. Link to comment Share on other sites More sharing options...
Dim Sum Posted February 1, 2012 Share Posted February 1, 2012 VVTi TT Supra? What boost are you running? If they haven't been changed already then I would fit new coil pack connectors as these become brittle over time and break, see how to guideHERE. No reason to change the coil packs unless they are faulty. There are no HT leads, the coil packs connect directly to the wiring loom. If you are fitting new plugs I'd also replace the 2 x cam cover breather hoses - remove the plastic engine cover and you'll see them - as these also become brittle and can easily split. This hoses you are talking about, is it just standard vacuum hoses? Link to comment Share on other sites More sharing options...
Nic Posted February 1, 2012 Share Posted February 1, 2012 This hoses you are talking about, is it just standard vacuum hoses? No they are shaped breather hoses, you'd need to order from Toyota, I don't have the part numbers to hand but someone on here may know. Link to comment Share on other sites More sharing options...
D8MOA Posted February 1, 2012 Share Posted February 1, 2012 for the sake ofanother £10 id replace the outer 2 rubber hoses as well Link to comment Share on other sites More sharing options...
Dim Sum Posted February 1, 2012 Share Posted February 1, 2012 for the sake ofanother £10 id replace the outer 2 rubber hoses as well Okay i keep this in mind when i change my as well. Might go to Toyota to see how much they want for those hoses. Link to comment Share on other sites More sharing options...
scotty71 Posted February 2, 2012 Share Posted February 2, 2012 Okay i keep this in mind when i change my as well. Might go to Toyota to see how much they want for those hoses. Get them off Paul Whiffin and support the traders, he sells them also Link to comment Share on other sites More sharing options...
