lots of bits left over after scrapping the car
barneybrendan
aircon matrix
Na coil
na igniter
distributer
engine mounts (SOLD)
front subframe steel
front subframe alloy
trd braided brake lines (SOLD)
lower glove box
stereo brackets
rear suspension top plates
seatbelts (DRIVERS BELT SOLD)
bonnet catches (SOLD)
windscreen wiper motor
door catches
osr quarter glass
horn
fuel cap & insert (SOLD)
handbrake levers (one now sold)
na throttle body matt black complete.
Osf abs hub with sensor.
Front upper wishbones (SOLD)
nsf lower wishbone (SOLD)
j spec rear discs (SOLD)
rear speaker brackets
cruise control ecu
brake master cylinder (SOLD)
brake servo
bonnet release cables and lever (SOLD)
tailgate and fuel cap release cables
osr upper wishbone (SOLD)
rear subframe (SOLD)
fuel tank and pump (GETTING DUMPED)
fuel tank gaurd (SOLD)
abs pump and lines
abs sensor and ecu
throttle pedal and stop
front anti roll bar
rear anti roll bar
rear tie arms
radiator hooks
fuel pump ecu
steering rack complete with track rod ends
steering column (SOLD)
front lower radiator panel
tailgate struts (SOLD)
lots of pipes.
Hi Bud,
Looking for the bonnet release cables and white box that sits above the FMIC(this splits the cables into 2) for the left and right catches. And also the release lever that sits under the dash in the cabin. :) this also has a spring with it
cheers bud
