scunner Posted February 1, 2012 Share Posted February 1, 2012 Service time has come around and Ive decided to buy all the parts myself. Ive ordered up the oils (Silkolene Pro S 5W40, and Royal Purple Gear Max for the TRD Diff) however I wasn't sure if the oil filter and air filter for the VVTI model is the same as the J Spec or UK Spec? Im also thinking about doing the timing belt while Im at it, are they the same for all TT models? I know the VVTI has a fair bit of difference but wasn't sure if these parts fall into that list? Any advice would be great. Quote Link to comment Share on other sites More sharing options...
Chris Wilson Posted February 1, 2012 Share Posted February 1, 2012 Same filters, be sure the purple stuff is for plate type diffs. Quote Link to comment Share on other sites More sharing options...
scunner Posted February 1, 2012 Author Share Posted February 1, 2012 Thanks Chris. I've had a look through a few sites about the oil and seems to be the right stuff (I hope!). You wouldn't happen to know if it's the same timing belt would you? Can't seem to find an answer anywhere? I'm thinking their the same as I have only seen the same type when I've been looking. Quote Link to comment Share on other sites More sharing options...
Paul Whiffin Posted February 1, 2012 Share Posted February 1, 2012 It's the same cambelt yep, I have all the parts in stock if needed. Thanks Paul Quote Link to comment Share on other sites More sharing options...
