engine removal
gavin.starr
im sure i have the manual on how to remove the engine on my harddrive back home. If you can PM me you email address i can send it to you:)
It will tell you everything you need to know.
Does this include instructions on putting it back again, inc torque settings etc?
If so, could I have a copy.
PM'ing you now.
  • 3 weeks later...
Cheers for this gugs, I completly forgot about this topic i set up.
With regards to an engine lift and stand what sort of weight rated on should i go for.
http://toolstoday.co.uk/shop.php?sec=prod&prod=3686&cat=2562&load_page=Sealey+Folding+Engine+Crane+1.8tonne+-+PH20
http://toolstoday.co.uk/shop.php?sec=prod&prod=54202&cat=2832&load_page=SIP+625Kg+Engne+Stand+-+03830
would these be ok.
would these be ok.
They would be fine but could be bought cheaper try;
http://www.ebay.co.uk/itm/NEW-FOLDING-2-TONNE-HYDRAULIC-ENGINE-CRANE-HOIST-/170566141580?pt=UK_Lifting_Moving_Equipment&hash=item27b688c68c#ht_3319wt_1165
http://www.ebay.co.uk/itm/SEALEY-ES550-ENGINE-GEARBOX-STAND-1012-LB-550-KG-NEW-/400176240549?pt=LH_DefaultDomain_3&hash=item5d2c5cd7a5#ht_3624wt_1165
You can get cheaper stands than the one i have just put up but i find its more sturdier with the two legs.
As for the crane i've got a similar design, i bought it five years ago, and in the past couple of years i have been taking at least one V8 Engine out of a Range Rover a week, so its more than up to the job!
Cheers craig.
Its going to be next month now until im going to buy, so i will get plenty of research in before i do.
The other question Im going to ask is, where is the best place to get a gasket kit from. Im hoping not to split the head from the block so i dont want a head gasket, Im basically after the intake gaskets, exhausts, sump gasket etc... Im going to give the engine a complete overhaul thats if my crank isnt buggered .
