lonbhold75 Posted February 1, 2012 Share Posted February 1, 2012 Connectors or part numbers(90980-11114 & 90980-11116, pins 82998–24180) for the facelift instrument cluster, MT and Turbo prefered. Don't really want the complete dash loom as I will be cutting it up, unless price is really good. UKDM head light leveling switch (84152-14040) and plug (90980-10801, pins 82998-12340;7ea.) as well as the plugs (90980-10891, pins 82998-12440, weather plugs 90980-09451;12ea) for the back of the headlight leveling motors Also looking for a damaged passenger side OEM sideskirt with the rear underside mounting section still intact, See attached image, part circled in red. Passenger side leather seat in good condition, may even be willing to trade my USDM electric drivers seat (UKDM/JDM passenger), depending on condition, etc. UKDM or JDM Drivers side A pillar trim. A JDM TT upper intake manifold and air intake box Broken/damaged ECU, mainly just want the connector to make my own adapter harness. A long shot, but also looking for a LHD dash panel the one with the radio, A/C controls, etc. Just want the panel, can even have a few holes/broken pieces. Any parts or information you can provide will be most appreciated Link to comment Share on other sites More sharing options...
Chris Wilson Posted February 1, 2012 Share Posted February 1, 2012 I may have a UK TT upper manifold /plenum. Any good? Link to comment Share on other sites More sharing options...
lonbhold75 Posted February 1, 2012 Author Share Posted February 1, 2012 I may have a UK TT upper manifold /plenum. Any good? Thanks, but I already have a US TT plenum, was wanting to get rid of the egr with out using block off plates. So it would look factory for visual inspection. Link to comment Share on other sites More sharing options...
lonbhold75 Posted February 12, 2012 Author Share Posted February 12, 2012 Still looking for some parts Link to comment Share on other sites More sharing options...
Iky Posted February 13, 2012 Share Posted February 13, 2012 You can get part numbers from toyodiy.com New connectors are cheapish but the terminal pins are expensive like a couple of quid each. Link to comment Share on other sites More sharing options...
lonbhold75 Posted February 14, 2012 Author Share Posted February 14, 2012 You can get part numbers from toyodiy.com New connectors are cheapish but the terminal pins are expensive like a couple of quid each. Well I must be blind, because I have searched toyodiy.com for the part numbers and all I can find is the number for the entire loom. If you could point me in the correct direction as to where to find the actual part numbers for the instrument cluster connectors it would be greatly appreciated. Link to comment Share on other sites More sharing options...
Iky Posted February 14, 2012 Share Posted February 14, 2012 Well I must be blind, because I have searched toyodiy.com for the part numbers and all I can find is the number for the entire loom. If you could point me in the correct direction as to where to find the actual part numbers for the instrument cluster connectors it would be greatly appreciated. You know what, you're right, i can't atually find them. i must have got mistaken. BUT I gues you didn't try google did you? http://www.supraforums.com/forum/showthread.php?435471-Are-All-Supra-Instrument-Panels-Same-Plug-In 90980-11114 & 90980-11116 These are only part numbers for the plastic connectors I'll try to find one for the terminals later. Link to comment Share on other sites More sharing options...
lonbhold75 Posted February 14, 2012 Author Share Posted February 14, 2012 Thanks for the numbers, I can find the terminal numbers from the TSRM now that I have the connector numbers. Nope didn't even dawn on me to try google, figured it would have been in here somewhere. Didn't expect to find the info on SF either. Thanks again much appreciated Link to comment Share on other sites More sharing options...
add heywood Posted February 15, 2012 Share Posted February 15, 2012 I have a stock J-spec plenum, pm me if you want it mate Link to comment Share on other sites More sharing options...
