Titan Motorsports Copper Supra rebuild for 2012 - going for the worlds quickest
nero
  • Replies 118
Cutting the roof gave us the ability to get the best cage clearance and also accessibility for weldingimage
You can see the seat being test fitted into the car. This is the old seat, we got something new coming :)
Here we decided to modernize the engine bay, which we do now on a lot of show cars. Complete welding and cleanup of the engine bay so that all the panels are smooth when painted. This is a lot of effort, but to get the best show look in an engine bay, its a must. Approximately 100 holes will be closed up. These holes are from things like the factory air intake, wiring harness clips, bolt holes for various factory pieces that are removed.
The view we hope all our competitors see. Went to dual parachute for additional safety at high speeds in the 1/4 mile image
Rear view hatch view
Decided to use a front motor plate on the Copper Supra. Like our other cars this will make everything for engine removal easy and also make it easy to transport spare motors.
Went ahead and rebuild the whole front area of the car, before the bars tied into the shock towers but were more direct and stopped at the shock tower; this time we go over the shock towers and hug the fenders to keep the bars out of the way and looking clean. Also this keeps the bar in 1 piece going over the shock tower but still ties the shock tower into the cage.
A shot of the finished welded piece
You can see in this picture the old shock tower pad's, which have the bar removed but the pad's for the rollbar still there.
With the front and rear motor plate, this allows the tranmsission and assembly to be seperate part of the car, also helps tie the whole car together with the motor assembly.
Sticking with the air/air intercooler. You may not believe it, but you will see an air/air intercooler on the car as it has been for years.
Another shot of the roll cage from above
Front Motor plate mounts
