pauld36 Posted January 31, 2012 Share Posted January 31, 2012 im sure this has been posted before because i cant believe im the only person who has unplugged the electrical wire to a seat belt. i cannot believe that there is no warning that it renders the seatbelt useless. to my question ,is there a way of resetting seatbelt,it looks like if clear plastic cover is removed that it might be able to be reset. any advice welcome ta Quote Link to comment Share on other sites More sharing options...
Scott Posted January 31, 2012 Share Posted January 31, 2012 I can't make head nor tail of any of that unfortunately Paul. Could you explain what you are looking for a bit better? Quote Link to comment Share on other sites More sharing options...
SupraStar 3000 Posted January 31, 2012 Share Posted January 31, 2012 you what? I've removed the seats before and never seen a seat belt plug? Quote Link to comment Share on other sites More sharing options...
pauld36 Posted January 31, 2012 Author Share Posted January 31, 2012 the front seat belts have an electrical connection at base,i unplugged the wire because i stripped car for welding of tunnel.when i put seatbelts back and connected wire they will not allow you to pull belt out ,so i disconnected and took to toyota dealers to ask advice .they stated that as soon as wire has been unplugged it renders the seat belt unuseable for ever. Quote Link to comment Share on other sites More sharing options...
Abz Posted January 31, 2012 Share Posted January 31, 2012 EDIT - I understand now Though not sure if that is true or not, have you tried reconnecting it a couple of times? Quote Link to comment Share on other sites More sharing options...
pauld36 Posted January 31, 2012 Author Share Posted January 31, 2012 you what? I've removed the seats before and never seen a seat belt plug? not seats the seat belt assembly Quote Link to comment Share on other sites More sharing options...
pauld36 Posted January 31, 2012 Author Share Posted January 31, 2012 I read it 3 times and still don't get it Are you saying the sign on the dash isn't coming on? Or that the seat belt end isn't working? the seat belts are locked and wont pull out Quote Link to comment Share on other sites More sharing options...
Scott Posted January 31, 2012 Share Posted January 31, 2012 Won't pull out of where? The seat belt buckle or the winding mechanism behind the panel? Where did you unplug it? was it at the winding mechanism or underneath the seat? I've removed the plug from the seat that connects to the seat belt buckle but I've never removed the pre-tensioner wire. It must be do-able though as plenty of people have sold seatbelts on here. Quote Link to comment Share on other sites More sharing options...
pauld36 Posted January 31, 2012 Author Share Posted January 31, 2012 EDIT - I understand now Though not sure if that is true or not, have you tried reconnecting it a couple of times? yes but on closer inspection theres a little metal solenoid that looks like when disconnected it activates a safety lock and toyota say it cannot be reversed and throw seatbelt assembly in bin .has to be replaced with whole new seatbelt assembly Quote Link to comment Share on other sites More sharing options...
Scott Posted January 31, 2012 Share Posted January 31, 2012 I take it you removed this wire while the battery was still connected then? Quote Link to comment Share on other sites More sharing options...
pauld36 Posted January 31, 2012 Author Share Posted January 31, 2012 Won't pull out of where? The seat belt buckle or the winding mechanism behind the panel? Where did you unplug it? was it at the winding mechanism or underneath the seat? I've removed the plug from the seat that connects to the seat belt buckle but I've never removed the pre-tensioner wire. It must be do-able though as plenty of people have sold seatbelts on here. the winding mechanism and the electrical plug[i now assume is the pre tensioner wire] Quote Link to comment Share on other sites More sharing options...
