Car stalls with some light throttle
ronttuk
yes it has a BOV so what could be wrong with the BOV ?
It stalls when pulling away as I take my foot off the throttle or just give it less gas the turbos are not usually spooling at that point.
Casey says MAF whats the MAF is that the bit between the air filter and the inlet manifold ?? What could be wrong with that ? tomoorow ill do a fault code test see what it comes up with
It isn't the BOV that's faulty as such, it's more the BOV causing the issue as the ECU is expecting more air than it is seeing... thus overfueling and stalling.
What BOV do you have? Some are less likely to do it than others.
The UK Supra is fitted with a MAF/Mass Air Flow sensor, this tells the cars ECU how much air is going to the engine, the ECU then adjust the fueling mix accordingly. When you lift off the throttle a vent to atmosphere BOV releases some of this air from the system causing a rich air/fuel mixture ie. too much fuel, which can cause the car to stall.
This is only a problem with the UK Supra, the J-spec Supra uses a MAP/Manifold Absolute Pressure sensor which is not effected by a vent to atmosphere BOV.
This may help you see what's wrong. It's Skyline experience based, but applicable here, too. It's part of my posts to a thread to another forum from 14 years back, so just read the gist of it.
The following is based on my Skyline experience, with air usage
measured by air flow meters before the turbos. It is not applicable to
cars that soley use a MAP sensor and throttle angle for air measurement .
To recap I put in a bigger intercooler and the standard Skyline duct
that runs across the lower front of the car taking dumped air from the
2 blow off valves to the intake between the air flow meters and the
twin turbo inlets was masking air exiting the lower 4 rows of the new
IC.
Having spent a good deal of money on this item it pained me to see some
of effectively blanked off. So I decided to blank the inlet off
altogether where the cross pipe entered the turbo inlet ducting, remove
the cross pipe and vent to atmosphere. The dump valves were being held
open at idle by the idle vacuum level, so after ages of pondering i
made a set up of solenoids to control when vacuum was applied to the
dump valves. This set up worked perfectly. *HOWEVER* a much more
serious problem occurred, which any similarly inducted turbo car will
potentially suffer if the boost air is dumped to atmosphere rather than
as standard into the air intakes after the AFM (s). On the overrun,
after a period of boost running, the standard set up will recirculate
the excess boost back into the turbos, through the IC, and back through
the dump valves to the turbo inlet again until the turbos inertia has
slowed them to the point of little or no boost. The AFM's do not see
any more air entering the engine, as it is being recirculated.
However, when we dump to atmosphere, that air is lost from the system
and the turbos draw in fresh air via the AFM (s). This causes the
engine to go mad rich, as the throttles are closed and no fuel is
really needed. Hence the black smoke seen on the overrun after my mods.
Worse still was a noticeable but very short period of detonation when
coming hard back on the throttle. This puzzled me totally, then it
dawned. As the fuel system started working normally again the Lambda
sensor "caught up" with what was happening, saw a very overly rich
mixture, and shut down the injector pulse width, creating a very lean
mixture, causing a brief, but very dangerous period of detonation!
I spent the afternoon and evening making new bracketry for the IC, new
hoses and adaptors and shifting the IC forward that critical 40 mm or
so, enabling me to fit the original moulded duct from the BOV's behind
the IC without blocking it. Quite a lot of work and fabrication...
However, the mod I was planning could well have caused damage, and is
certainly something to be very aware of if one has a similar AFM pre
turbo set up changed to dump boost to atmosphere. The type of BOV
matters not, it's the fact that the air no longer re circulates but is
lost from the system, confusing the AFM (s) into thinking the engine is
wanting more air/fuel mixture. An oscilloscope on the O2 sensors
confirmed what was happening. We live and learn, often the hard way,
but in this case not as hard a lesson as it might have been. I hope
this helps, I searched the web long and hard for references to BOV
problems, and failed to find any details of why dumping to atmosphere on
none MAP sensor systems, that aren't mapped for this, is potentially
dangerous.
I can now finally make some proper seals to make sure all air entering
the radiator ducting passes through the IC, something HKS totally fail
to address, at the moment most air will go around rather than through
the IC core.
The BOV is a HKS 1
One, not 1 ;)
As above, if you don't want the hassle either just ditch the aftermarket BOV in favour of a stock one or fit the recirculating attachment to the HKS. If you really want the aftermarket type then I would look at a different model as yours is leaking a bit by the sounds of it (if it's just at low revs this is happening).
IC.
dangerous.
the IC core.
my supra has a afm fitted and a vent to atmosphere dump valve and has no problems with stalling, what you said above makes sense, but i thought it would be ok as after a period of boosting then letting of the throttle the injectors shut down on the over run until about 1500 rpm or so?, or a i missing somthing. regards chris
