Si_s Supe Posted January 29, 2012 Share Posted January 29, 2012 Just about to start refurb'ing my UK spec calipers as they're looking a bit shabby. They're split in half and all pistons removed and got new seals, boots and transfer seals coming from CW. Also got some fresh decals to go on. Looking for suggestions on colour / paint to use!? I'm thinking satin black then decals on and then over the top with a satin lacquer to seal them up? I've painted calipers before using normal satin paint from Halfrauds with good results as the calipers don't get TOO hot to warrant heat resistant paint. Is this the case with UKs?? Quote Link to comment Share on other sites More sharing options...
Josh Posted January 29, 2012 Share Posted January 29, 2012 I bought some straight to metal satin black Hammerite. Sticking the decals on then possibly lacquer, but a test I did showed it to just "melt" the paint. Quote Link to comment Share on other sites More sharing options...
little num Posted January 29, 2012 Share Posted January 29, 2012 i had mine powdercoated in red with BREMBO stickers fitted on, ill put a pic up if you like they look Mint. Quote Link to comment Share on other sites More sharing options...
Si_s Supe Posted January 29, 2012 Author Share Posted January 29, 2012 How much did it cost for powder coating? Why did you put brembo stickers on may I ask??? Josh, that's answered my question for normal paint on these calipers then! They obviously get hotter than the 4 pot 200sx brakes I did. Looks like high temp paint FTW then. In which case, I'd consider metallic black which is actually more of a dark gunmetal colour then a stain lacquer. Quote Link to comment Share on other sites More sharing options...
Robzki Posted January 29, 2012 Share Posted January 29, 2012 Why would Uks get hotter than jspecs? Mine are painted in hammerite(smooth) and always look clean and shiny One of my calipers seized on the way to and from japfest last year(300 miles) and the paint still looked as good as new, the discs on the other hand didn't. Quote Link to comment Share on other sites More sharing options...
Josh Posted January 29, 2012 Share Posted January 29, 2012 How much did it cost for powder coating? Why did you put brembo stickers on may I ask??? Josh, that's answered my question for normal paint on these calipers then! They obviously get hotter than the 4 pot 200sx brakes I did. Looks like high temp paint FTW then. In which case, I'd consider metallic black which is actually more of a dark gunmetal colour then a stain lacquer. I asked the chap at the local parts shop if he had any high temp paint and he said not to bother, normal paint would be fine. Quote Link to comment Share on other sites More sharing options...
Si_s Supe Posted January 30, 2012 Author Share Posted January 30, 2012 I asked the chap at the local parts shop if he had any high temp paint and he said not to bother, normal paint would be fine. I'm confused now, I thought it melted?? Quote Link to comment Share on other sites More sharing options...
Robzki Posted January 30, 2012 Share Posted January 30, 2012 Mine hasn't, I'm no expert but people buy stickers from ebay and put them on their calipers. I doubt that ebay stickers are made from thermonuclearheatresistantteflon. Quote Link to comment Share on other sites More sharing options...
Josh Posted January 30, 2012 Share Posted January 30, 2012 I'm confused now' date=' I thought it melted?? [/quote'] Not from heat. On a test patch I did on a sheet of metal, when I put the lacquer on, the paint went soft. Although the parts where I'd sprayed the lacquer and left it over night were fine. Sorry for the confusion Quote Link to comment Share on other sites More sharing options...
Hellstrom Posted January 30, 2012 Share Posted January 30, 2012 Why would Uks get hotter than jspecs? Mine are painted in hammerite(smooth) and always look clean and shiny One of my calipers seized on the way to and from japfest last year(300 miles) and the paint still looked as good as new, the discs on the other hand didn't. Uk spec is alloy vs cast alloy soaks more heat dunno if there is a problem. I used 2 componet when i painted mine --- I am here: http://maps.google.com/maps?ll=57.735428,11.940319 Quote Link to comment Share on other sites More sharing options...
k9l3 Posted January 30, 2012 Share Posted January 30, 2012 black is boring go red always looks good and sporty on cars . with black stickers Quote Link to comment Share on other sites More sharing options...
Hellstrom Posted January 30, 2012 Share Posted January 30, 2012 I love em white! --- I am here: http://maps.google.com/maps?ll=57.747342,11.797020 Quote Link to comment Share on other sites More sharing options...
Havard Posted January 30, 2012 Share Posted January 30, 2012 Had white calipers on my NA. Just painted then with Hammerite and never had a problem. On the TT we did the same with black and new decals. A year later they look as if they have only just been done. H. Quote Link to comment Share on other sites More sharing options...
Dnk Posted January 30, 2012 Share Posted January 30, 2012 (edited) Brembo stickers on stock calipers Heres a pair i did in powdercoat If you've got them stripped get them chemi dipped and smooth off all the casting marks, i then fine media blasted these and then Ibrar powdercoated them for me after i'd cleaned them meticulously and refitted the two halves back together and masked of the piston bores. Edited January 30, 2012 by Dnk (see edit history) Quote Link to comment Share on other sites More sharing options...
Si_s Supe Posted January 30, 2012 Author Share Posted January 30, 2012 Wow, they look great. Unfortunately, I don't think my budget is going to stretch to powder coating at the moment though. I like the idea of the chemi dip though as I had some seized brake pins and there is penetrating oil everywhere. Is it ok to get the chemicals in the piston bores?? Also, if they're blasted, how do you stop it getting inside the calipers? Surely tile blast masking tape away? Quote Link to comment Share on other sites More sharing options...
Dnk Posted January 30, 2012 Share Posted January 30, 2012 (edited) Wow' date=' they look great. Unfortunately, I don't think my budget is going to stretch to powder coating at the moment though. I like the idea of the chemi dip though as I had some seized brake pins and there is penetrating oil everywhere. Is it ok to get the chemicals in the piston bores?? Also, if they're blasted, how do you stop it getting inside the calipers? Surely tile blast masking tape away?[/quote'] The masking tape is only on to stop the powder coat getting into the piston bores and where the pads sit. This area around the piston bores was hand painted with black high temp paint. I media blasted them which doesn't do any damage to the piston bores, the piston bores are a clearance fit on the pistons so its not an issue. I wouldn't just hand them over to anyone to do this as you dont want them shot blast by someone who just uses old tech steel ball shot. Speak to Ibrar at Speedwells They were washed out with brake cleaner and blown clean with an airline repeatedly to make sure theres no grit or dirt etc in or on the calipers. Then they were bolted back together and masked up as in the pic also using other bolts to block off the threads for the bleed nipples etc Chemically stripping them isnt a problem and im pretty sure they used phosphoric acid which is neutralised with water. Edited January 30, 2012 by Dnk (see edit history) Quote Link to comment Share on other sites More sharing options...
little num Posted January 30, 2012 Share Posted January 30, 2012 (edited) Here are mine, they taped off the top of the pistons and fitted them back in to stop any sandblast going into the calipers and then acid dipped to a nice clean condtion. They was then powdercoated to give them a long lasting finnish i hope. New seal kit fitted and look new. Im not keen on having the supra logo on the calipers and they just look bare with nothing on, so decided to get some brembo decals made and i think they look good, dont really care what anybody else thinks. Edited January 30, 2012 by little num (see edit history) Quote Link to comment Share on other sites More sharing options...
