Adjustable Rear Control arms?
JamieP
I need some adjustable rear control arms for my car, i like it low and im running to much camber to get the most out of my 335 wide rears, ive seen the Titan/PHR and Ikea ones, anyone had any problems with them?
Or do you know of other make ones, Im sure there are others available?
http://www.titanmotorsports.com/timorecoarmk.html
http://powerhouseracing.com/Templates/frmtemplateM7.asp?SubFolderID=22&SearchYN=N
Hi Jamie,
I'm running the full Ikeya set (I got mine through Nic, though RHD Japan is one possibility: http://www.rhdjapan.com/toyota/jza80-supra/links-rods-arms), and combined with the ProEFI, the stability in the rear is phenomenal... I personally haven't had experience with the PHR gear though was previously running the Titans which were also great.
The PHR ones look really cheap IMO, I would always choose the Ikea just based on the way the PHR ones look.... knowing of course how good the Ikea ones are anyway. I held a set of rear lowers in my hand and they really didn't look to clever for the money involved.
Wont you need both the upper and lower arms ?
The stock rear lower arms haven't exactly got lots of adjustment, obviously depends how much you
need to pull the top in by as i guess your having clearance issues if you reduce the camber
There are other sources for them, but I have had nothing but positive experiences with RHD Japan. I'm sure there are other members here who have ordered through them. Quite a few aussies use them too in addition to nengun and greenline.
Edit: Just a couple from a quick search:
http://www.mkivsupra.net/vbb/showthread.php?260867-Interior-retrim-ideas&p=3281899&highlight=rhdjapan#post3281899
http://www.supraforums.com/forum/showthread.php?654012-Ogura-clutches&p=8555349&highlight=rhdjapan#post8555349
I dont have any clearance issues, loads of room in there, its just the stock rears are max'd out on the settings and id still like to pull out another degree of camber, if i raise the back a little its fine but i like it low on my 18's
Yeah i want the Ikea ones, £622 with delivery aint bad, would like some feedback about rhd japan before i order though.
Jamie, I bought loads of stuff of RHD Japan a few years back. Very good prices back then and the more you buy the cheaper the prices. No issues with them and delivery was secure and quick.
