active exhaust systems
dr_jekyll
does anybody have info on who makes active exhausts or where i could have one fitted to my xkr.
i love the fact that my car is silent when cruising and generally running around but a guy came to the jag place next to me yesterday with straight through pipes and the sound was mind blowing , but far to loud and harsh to live with all the time, so as ever i want the best of both worlds so a nice active sytem that will open on WOT only wilkl do nicely. just need to find one .
as ever all help is greatly apriciated. thanks you lovely bunch
I have fabricated a couple of valve bypass exhausts in the past, there are quite a few pre made valve sections available, either electronic control, wire linkage, vac actuator ect, last setup I used a couple of truck exhauster brake valves to bypass as I sourced these inthe stainless size I needed
I'm sure if you buy the butterfly valve you could get your local stainless exhaust fitter/fabricator to do wotever you want spec wise
