masterfett Posted January 25, 2012 Share Posted January 25, 2012 sorry if this has already been covered but i cant find the correct answer! so im looking to get some rota gtr wheels 18 x 8.5 front on 235 tyres and 18 x 9.5 rear with 255 tyres.. im fairly confident et30 will be fine on the front question is...what about the back will et30 cause problems. suggestions opinions and advice welcome! thanks Link to comment Share on other sites More sharing options...
Westy Posted January 25, 2012 Share Posted January 25, 2012 Do you have j spec or UK spec calipers!? Link to comment Share on other sites More sharing options...
Scott Posted January 25, 2012 Share Posted January 25, 2012 ET30s will be fine with those sizes. Link to comment Share on other sites More sharing options...
masterfett Posted January 25, 2012 Author Share Posted January 25, 2012 uk fronts.. cheers guys, was just unsure if that extra 5mm was gunna rub the back..or id get et35 if it would Link to comment Share on other sites More sharing options...
Scott Posted January 25, 2012 Share Posted January 25, 2012 uk fronts.. cheers guys, was just unsure if that extra 5mm was gunna rub the back..or id get et35 if it would ET35s would be better with larger tyres but with 255s they should be fine. The height of your car might have a fair bit to do with it though. Link to comment Share on other sites More sharing options...
-Welsh-Stealth- Posted January 25, 2012 Share Posted January 25, 2012 Got these in gunmetal over UK spec brakes. Not sure of the offset, think et35 & et30. Rota will be able to confirm what you need sorted me out no problems. Running 18" j8.5 front & j9.5 rear with 235/35& 255/40 tyres. Link to comment Share on other sites More sharing options...
