1993 supra ta project to a1998 ttvi twin, auto to 6 spd open rear to limited slip
Guest Kmichael
Guest Kmichael
Need help with the throttle etcs-1. Have 5 vts at blue red wire and the tps seems to om out ok but cant get any responce
engine starts runs good but in limp only revs up only last 30% of throttle. Others have said to hook up blue red wire from
lower fuse area and we did with a 15 amp fuse link. I am ready to tear off and go manual. Is there somthing we missed
If anyone has any ideas we are all ears THANKS FOR HELP, Kevin
Keep an eye on this thread:
http://www.mkivsupra.net/vbb/showthread.php?260557-Problem-with-VVTi-Throttle-Body
And this one might be useful too:
http://www.mkivsupra.net/vbb/showthread.php?232824-J-Spec-Engine-Harness-Connector-Details/page3
I have the exact same problem, and still tracing it... Will write as soon as I find it...
Check the voltage on the Throttle Valve Motor. I don't have the +12v on it.
Edited by EMPEROR (see edit history)
Guest Kmichael
Thanks for geting back your wiring matches our ecu and shell with only a couple of different ones that go to the same place.
If allels falls you can put a q45 ithrottle with a couple mods on it and it will be manual but not sure about tps that still worries me
Check post 41 on the second link. You will see which connector and which pin you should check. I guess you are using the VVTi engine wiring harness. Or whatever you have modified, you still have the connector for the throttle valve motor. You should check if you have 12v on it, I am not talking about the upper fusebox connector.
P.S. Btw, on the blue-red wire on the upper fusebox connector, you should have 12v, not 5v
http://i224.photobucket.com/albums/dd108/wilbo666/final314.jpg
Guest Kmichael
Yes vvti stock harness. I dont have 12v to the throttle valve motor eather and pin 3 is the only grounded wire. I ment 5v on the blue/red wire on the throttle position sensor
