New product- 2 different pulley sets
Rob_Mitchell
  • Replies 85
the grade of ali is 6082, its a machining grade ali.
weights are as follows
stock alternator pulley = 273g our pulley= 91g
stock water pump= 455g our pulley= 182g or 163g (depends on design)
Thanks Rob :thumbs:
Is that tempered to T4,T6 or T651 :D
This is the differance tempering makes, thought i'd get really anal for you :D
Proof Stress 0.2% (MPa)
60.....................................temp 0
170 ..................................temp t4
310...................................temp t6/t651
Tensile Strength (MPa)
130..................................temp 0
260..................................temp t4
340..................................temp t6/t651
Shear Strength (MPa)
85...................................temp 0
170.................................temp t4
210.................................temp t6/t651
Elongation A5 (%)
27..................................temp 0
19..................................temp t4
11..................................temp t6/t651
Hardness Vickers (HV)
35.................................temp 0
75.................................temp t4
100................................temp t6/t651
These will look awesome in anodised purple ;)
And Dunk is a proper geek lol!
Im an enginnering geek i'll have you know :D The figures i posted dramatically show the differance of the same
grade of aluminium alloy after a bit of tempering so you really do need to know the exact spec of the material
your using,
Robs is spot on and also very good for anodising :)
Without guys like me you'd still be walking or riding a horse :D
your using,
Robs is spot on
My guy does things like this all day and his work is faultless and top quality. Nothing but the best for the under bonnet treats. I should have a finished set by next week i hope but im waiting for the power steering shaft to arrive first.
Glad to here it Rob :)
