1jz to w58 Gearbox Wiring
welshbuddy
ok need help with the gearbox wiring, as the Soarer 1jz gte, had a automatic gearbox, we cut the Loom when removing the engine as we didn't need it, so we now have the problem of wiring the gearbox up.
these are the plugs from the N/A loom that went to the gearbox.
need to know what they control if they go to the gearbox. And because it is on the N/A engine still , how far does the Loom go under the manifold?.
And also, say if you didn't connect them. Would the car run? What does it control?.
thanks daz.
