Chris Wilson Posted January 21, 2012 Share Posted January 21, 2012 I now have a stock of front and rear pistons for UK calipers. I also have stainless brake pin kits for the UK and Jap spec calipers. i will sell as either full sets, or just fronts or rears as required. UK pistons: Fronts are £18 per piston and rears are £21 per piston. Jap type pistons: Fronts are £22 per piston, rears are £24 per piston (much more material used). I also have the special material square section seals that go between the caliper halves when you split them to replace the pistons. These are not even listed, let alone available from Toyota. They are £4.50 each and there are two per caliper. They must be changed... P&P for pistons is £7.80 to UK postcode addresses, sent insured and trackable. Brake pin kits in stainless for all four UK calipers are £36 a set, plus £5.80 insured P&P, or at YOUR RISK, £2.50 by untrackable Royal Mail parcel. I am able to offer caliper piston seals and dust / water boots at a saving on Toyota prices. Let me know what you need please. I am happy to rebuild calipers for people, but don't want to get involved painting in other than black Kephos, or a customer supplied finish. I am unable to powder coat them, sorry. Payment by bank transfer or Paypal plus 4%. Prices are plus VAT. I do not take credit card payments, sorry. Orders by **E-MAIL** please. I have constantly changing stock levels at the moment. J-Spec pistons are now also available, as are seal kits. By using stainless you will stop further seizure by the chrome plating on stock pistons pitting and flaking and general rust issues on old standard Toyota pistons. If you don't know what you are doing take your calipers to a professional, the old pistons need to be nearly all the way out BEFORE you remove the calipers from the hydraulic system on the car!!!!! This means pumping them out evenly, with an assistant holding "eager" pistons back with a lever, with no pads in the caliper, one caliper at a time, then wedging the pistons that are almost out whilst you move to the next one, remove the pads and do the same again. Home made wooden wedges etcetera work fine. Getting partially seized pistons out of calipers on the bench is a nightmare. ALL prices here are plus VAT. Link to comment Share on other sites More sharing options...
little num Posted January 21, 2012 Share Posted January 21, 2012 hi chris, how much is the front refurb kit for the uk calipers, im not splitting the calipers so wont need the o ring that fits between. All i need is the square seal that holds the piston in and the dust covers kit. Ill price them from toyota as well as i get a good discount these days. Link to comment Share on other sites More sharing options...
Chris Wilson Posted February 10, 2012 Author Share Posted February 10, 2012 Bump Link to comment Share on other sites More sharing options...
mellonman Posted February 10, 2012 Share Posted February 10, 2012 Chris how much is the rear uk seal kit, is this a oem kit Link to comment Share on other sites More sharing options...
Chris Wilson Posted February 10, 2012 Author Share Posted February 10, 2012 £32 + VAT, it's an AP kit. I may have an OEM one, same price, look to be the same seals to be honest... Link to comment Share on other sites More sharing options...
Dan_Turism0 Posted February 10, 2012 Share Posted February 10, 2012 Hi Chris, Could you give me a rebuild cost for rear UK's with the stainless pistons/pins/seals? Link to comment Share on other sites More sharing options...
mellonman Posted February 10, 2012 Share Posted February 10, 2012 also goes the kit come with the lithium grease like the toyota kit? Link to comment Share on other sites More sharing options...
Chris Wilson Posted February 10, 2012 Author Share Posted February 10, 2012 I can put some in a seal top bag if you don't have any. Enough to do whatever number of seals you buy. Link to comment Share on other sites More sharing options...
Chris Wilson Posted February 10, 2012 Author Share Posted February 10, 2012 Hi Chris, Could you give me a rebuild cost for rear UK's with the stainless pistons/pins/seals? I can't powder coat them or do any fancy finishes. Your choice of colour is black, or black Link to comment Share on other sites More sharing options...
Dan_Turism0 Posted February 11, 2012 Share Posted February 11, 2012 black would be fine Chris not looking for powder coating Link to comment Share on other sites More sharing options...
