samsupra37 Posted July 26, 2005 Share Posted July 26, 2005 Help!!! I need a turbo!!!! Desperate. Gregsupra4's K nut flew off gave and installed my brand new turbo on his car, the turbo that came off only needed the k nut replacing and rebalancing, unfortunatley the company charged with this job, in their infanet wisdom took it apart and damaged it, now cannot get the parts to replace. Am installing 880 injector new fuel rail and f-con need 67/70ish turbo.......the downside is need it now.......can any one help...PLEASE...PLEASE :thumbdown Quote Link to comment Share on other sites More sharing options...
JustGav Posted July 26, 2005 Share Posted July 26, 2005 Busy seeing what I can do for you sweetie.... (hence the reason I'm on the phone with you) *grin* Quote Link to comment Share on other sites More sharing options...
samsupra37 Posted July 26, 2005 Author Share Posted July 26, 2005 I know all help is appreciated but had to see if any one else would help a lady in distress!!!! Quote Link to comment Share on other sites More sharing options...
absz Posted July 26, 2005 Share Posted July 26, 2005 i've got a stock twins complete with manifold for a uk spec if you're intrested Quote Link to comment Share on other sites More sharing options...
samsupra37 Posted July 26, 2005 Author Share Posted July 26, 2005 thanks absxxxx but getting away from the twins looking to upgrade to a large single or at least thats the plan......or at least it was the plan, might have to look at changing the plan....supposed to be at the pod 5,6,7th august and was hoping to be competative.....not looking likely now!!!!! Quote Link to comment Share on other sites More sharing options...
absz Posted July 27, 2005 Share Posted July 27, 2005 samsupra37 just for reference what is a K nut ? as i have ordered the same turbokit as gregsupra4. i guess its somthing that will need checking. Quote Link to comment Share on other sites More sharing options...
Alex Posted July 27, 2005 Share Posted July 27, 2005 PM Matt Harwood or Migster on here...they maybe able to supply a T61/67/71. Quote Link to comment Share on other sites More sharing options...
samsupra37 Posted July 27, 2005 Author Share Posted July 27, 2005 ABSxxx, its the nut on the end that holds it all in place......why K nut your guess is as good as mine. I don't think you will have to worry as the other one the new one is fine and has no probs at all. Think it may not have been done up tight enough but you can never tell. Quote Link to comment Share on other sites More sharing options...
samsupra37 Posted July 27, 2005 Author Share Posted July 27, 2005 PM Matt Harwood or Migster on here...they maybe able to supply a T61/67/71. Thanks will give him a try..... Quote Link to comment Share on other sites More sharing options...
