First Drive After BPU...
Notts_TT
Hi
Took to Supra for a quick Blert today to see how it runs after full BPU.
I noticed the afr reads 10 when cold, 12.5 at warm idle, 11 when hard accelerating and 14.5 when crusing at 60...
Also i fitted a 1 bar rr and have wired in a aem truboost, i havent touched the boost controller yet but noticed it was boosting at 16.5 ish psi, is there no need
for the truboost ???, should i adjust gain feature ?
Please let me know what you guys think...
Thanks [GRIN][/GRIN]
Your cruise values are spot on, so I'd expect warm idle to be correct as well. The oil temps have to be around 50degC before it drops into closed loop. If your O2 sensor is "bouncing" around a value then it's in closed loop, if it's a steady value it's still in open loop.
Also, there isn't really such a things as a "1 bar restrictor ring", as each car can be different. You probably need a narrower ring if you really want 1bar of boost, but I wouldn't worry about it as you'll just run richer and have less power :)
