Various 2JZ and 2JZ-GTE engine seals / gaskets.
Chris Wilson
My high tension oil pump seals, special seal with added lip tension, a good bet for fixing the dreaded front seal leak where the crank has a wear groove worn by the old seal. £28 plus VAT each
Rear main bearing seals, 1/3 rd Toyota price, a small job lot, will soon go. My price £16.98 plus VAT.
Gear shaft selector seals for six speed manuals, a special seal that doesn't entail you performing the almost impossible task of getting the old seal out without scoring or scratching the selector shaft itself and making things 100 times worse. Just thoroughly clean with brake cleaner, tap the old seal in further, and put the new on in in front of it. A trick used on old BL cars with similar selector shaft issues. These special seals are £4.80 plus VAT each, I have but 6 of them.
Cam shaft seals, 1/2 list price. All sold today. I may be able to get a few more, will check, but i am doubtful.
Gearbox rear seals, manual only, 1/2 Toyota price, very few left. My price £18.82 plus VAT.
Postage can be an insured by courier £5.80 plus VAT, or a your risk £2.50 by normal mail.
I pair N/A genuine Toyota multi shim exhaust manifold gaskets, been on an engine that someone brought to me to fit, started it, ran it for 10 minutes, found it a scrapper and he bought a TT conversion. £14 pair. Mint, still retaining embossing, so will definitely seal as new. These are DEAR from Mr T.
I set valve stem seals, inlet and exhaust, offers. New of course.
One only TT head gasket.
E-MAIL responses please, not PM's, see sig.
Thanks.
One HT oil pump seal and 2 camshaft seals are £42.97 plus VAT (£51.54) posted by insured courier.
Here are Toyota retails:
Oil pump (front crank seal) £17.77 plus VAT
Rear crank seal £50.93 plus VAT
Cam seal (one) £9.17 plus VAT
6 speed V160 / V161 rear seal £37.63 plus VAT
6 speed V160 / V161 front seal £40.24 plus VAT
6 speed selector shaft seal £ 6.98 plus VAT
So big savings to be had from me, whilst stocks last.
