someone recommend me fuel injectors
Guest George89
Guest George89
I am purchasing a Precision 6265 turbo to finally go single. can someone recommend me some drop in injectors? i am after 550-600rwhp also running Emanage ultimate.
Wouldn't 800cc be better Nic? Just for that safety margin?
Possibly, the OP mentioned he was using an Emanage Ultimate, I am no expert when it comes to mapping so probably best for him to get advice from whoever is mapping the car which would be the better size to go with, the 650cc injectors should be adequate with the turbo he is using but PE SH800A injectors may be worth considering.
Guest George89
I have heard a while ago that the emanage ultimate won't really be able to cope with anything over 800cc so will need to speak to ryan (2bartuning)
I might as well stick with 700cc to be in the middle
Don't think there are any companies that do 700cc injectors that will fit the stock fuel rail.
Power Enterprise do 550cc, 650cc and 800cc injectors to fit the Supra fuel rail.
Guest George89
i just had a quick look and power enterprise injectors seem to be around £700-£800 i might as well get whifbitz top feed fuel kit for that sort of money!
