jake supra Posted January 17, 2012 Share Posted January 17, 2012 Hi all Need some advice on what turbo would be best suited for my na-t build. At the present I have a t3 manifold and a cheap eBay t3 copy turbo that is maxed out at around 400bhp. It has a internal waste-gate which is annoying as im going to be running an external 38mm one. Im Looking for something that can handle around 500bhp and needs to be T3. budget around 400pounds. Iv looked at this one on bay not sure if its any good tho: http://www.ebay.co.uk/itm/200620238765?ssPageName=STRK:MEWAX:IT&_trksid=p3984.m1423.l2649 Thanks in advance for any advice. Jake Quote Link to comment Share on other sites More sharing options...
abtin90 Posted January 17, 2012 Share Posted January 17, 2012 Something like a precision 6262 or garret gt35r would be good. Though you'd need to lower your compression first with a thicker head gasket or ideally tt piston to run more boost. Quote Link to comment Share on other sites More sharing options...
jake supra Posted January 17, 2012 Author Share Posted January 17, 2012 I'm going to be running around 7psi. Then maybe upgrading to a thicker HG. Want something that I can up the boost on If i go for more Power. Quote Link to comment Share on other sites More sharing options...
Noz Posted January 17, 2012 Share Posted January 17, 2012 that ebay turbo should be fine for those power levels. that should spool quicker than the T61's that are flying about. Quote Link to comment Share on other sites More sharing options...
jake supra Posted January 17, 2012 Author Share Posted January 17, 2012 that ebay turbo should be fine for those power levels. that should spool quicker than the T61's that are flying about. Yep it looks decent enough. Just hope its good build Quality and not some cheap copy. Quote Link to comment Share on other sites More sharing options...
Noz Posted January 17, 2012 Share Posted January 17, 2012 cheap turbos are cheap copies mate, but doesnt mean they are all bad quality. unless you pay big bucks you can only hope that it lasts Quote Link to comment Share on other sites More sharing options...
jake supra Posted January 17, 2012 Author Share Posted January 17, 2012 cheap turbos are cheap copies mate, but doesnt mean they are all bad quality. unless you pay big bucks you can only hope that it lasts Im sure your right. Is your T61 a copy or branded. How is it performing? Quote Link to comment Share on other sites More sharing options...
Ian C Posted January 17, 2012 Share Posted January 17, 2012 (edited) I was going to suggest a GTX3076R but then I saw your budget! £400 for a turbo? Is that possible? Edit - checked the ebay ad. Well, hmmm, there are a few maxims I could trot out here, like "you get what you pay for", "if it's too good to be true it probably is", "pay cheap, pay twice" and so forth. Genuine Garrett turbos of this ilk are around £1500 to £1800. They are at the forefront of turbo technology so that price covers a lot of R&D spend, so maybe a copy at the same quality levels would be in the region of £1000 to £1200? But £400 you have to ask where the corners have been cut. Mind you, on the other hand, for £400 it might be worth a punt The only real risk is if it blows and the engine sucks bits of the exhaust wheel back into the engine & trashes that. Or it spits oil onto the exhaust and sets fire to the car. Both are pretty remote, so meh. Edited January 17, 2012 by Ian C (see edit history) Quote Link to comment Share on other sites More sharing options...
jake supra Posted January 17, 2012 Author Share Posted January 17, 2012 I was going to suggest a GTX3076R but then I saw your budget! £400 for a turbo? Is that possible? I can spend more. I was thinking getting a good copy first then investing in a quality branded one something like a Garrett. Quote Link to comment Share on other sites More sharing options...
JakeG Posted January 17, 2012 Share Posted January 17, 2012 I could be wrong but I'm pretty sure you need to do the head gasket when going na-t, you can't just wait a while and do it further down the line Quote Link to comment Share on other sites More sharing options...
Ian C Posted January 17, 2012 Share Posted January 17, 2012 I can spend more. I was thinking getting a good copy first then investing in a quality branded one something like a Garrett. I edited my post above Garrett turbos aren't cheap but they are quality and there is the backup support if you get problems. Quote Link to comment Share on other sites More sharing options...
jake supra Posted January 17, 2012 Author Share Posted January 17, 2012 (edited) I could be wrong but I'm pretty sure you need to do the head gasket when going na-t, you can't just wait a while and do it further down the line I Could be wrong as well but thought aslong as you run a low psi. Think 6 or 7psi then The engine can handle the boost. Edited January 17, 2012 by jake supra Spelling (see edit history) Quote Link to comment Share on other sites More sharing options...
Nic Posted January 18, 2012 Share Posted January 18, 2012 http://www.ebay.co.uk/itm/200620238765?ssPageName=STRK:MEWAX:IT&_trksid=p3984.m1423.l2649 For that price it'll be a Chinese made turbo, I regularly get sent emails from Chinese manufacturers trying to flog turbos, personally I would not waste my money. With a budget of £400 I would look at sourcing a good quality second hand turbo rather than buying new, a Garrett GT35 or GT35R with T3 housing would be a good choice. Quote Link to comment Share on other sites More sharing options...
