Black 6 Speed Ridox Single £18,000 SOLD!!!
Geo
Here we have for sale is my Black Supra RZ 6 speed Ridox Single. I've had the car for 6 years, I got it Imported through Jm-Imports August 2006 and i'm the only UK owner of the car. The car has done 175km = 108,000 miles. It has recently been built by Supra Racing Developments (SRD) who have truly transformed the Car. And Tuned safely by RyanG @ 2bartuning. The car has been shot for Performance Import magazine which will be out this year at some point. The car has variable boost settings 1.7bar, 1.5bar, 1.3bar, and 1.1bar, with a cruise setting for better MPG.
The car has 712bhp - 602ftlbs @ 605rwp @ 1.7bar Dyno Sheet Available :)
Car is MOT'd and Taxed Till August 2012.
Below is the full Spec with Pics
Engine Specifications:
Toyota Stock Straight 6 Engine
NGK Plugs BKR8EIX
HKS 256/264 Cams
Greddy Plenum
Q45 Throttle Body
Bosch 044 Fuel Pump
Larger Lexus Oil Filter
3'' ToyoSports FMIC
Whifbitz Bonnet dampners
New Exhaust Manifold Gasket
New Inlet and Exhaust Cam Cover Gaskets
Turbocharger & Induction:
Precision T6765 .68(67mm turbo with .68 ar)
HKS Racing BOV
Whifbitz Tubular Manifold
Whifbitz 3'' Mid/Down pipe
Unorthadox Racing Pulleys
Toyota OEM Engine Gasket Set
Toyota OEM water pump
Toyota OEM timing belt idler wheel
Toyota OEM timing belt tensioner
Toyota OEM crank shaft pulley
Toyota OEM exhaust manifold nuts x12
Toyota OEM Timing Belt
Whifbitz Adjustable Cam Gears
Fuel Lab 535 FPR
SRD Billet Water Inlet Pipe
TRD Thermostat
SRD Heat shield
Water output pipe Smoothed off and Polished
4'' Polished Intake Pipe
4'' K&N Filter
Whifbitz Breather Tank
Braided Oil Feed and Return Lines
50mm Turbosmart Waistgate
Fuel, Tuning & ECU:
Syvecs ECU, with adjustable boost settings and Trac Control
3.5 Bar AEM Map Sensor
Power Enterprise 800cc Injectors
Injector seals
Stock Fuel Rail
Stock Fuel Filter
AEM wideband
Fuel Pulsation Dampner
1/8 NPT straight fitting
Cooling:
3'' ToyoSports FMIC with Custom Piping
Koyo Radiator
Supra FMIC and Rad Cooling plate
AAP Motorsports Dual Fan Kit with Shroud
Heat Wrapped Down/Mid Pipe
HKS Oil Cooler
Blitz 1.4bar Rad Cap
Power Steering Cooler
Exhaust:
Supra Dragger 4'' Exhaust, with a 3'' Full System leading to Turbo.
Envy Decats
Drivetrain:
6 Speed Manual Getrag Gearbox
Whifbitz Solid Gearshift Bushes
Toyota Gear Selector Seal
Stock Jspec Diff
Whifbitz Solid Selector Bushes
Southbend DXD-F Series Clutch
clutch cover washer
Suspension, Wheels, Tires & Brakes:
UK Spec Brakes all Round 4/2 Pot(Front and Rear)
OEM Disks, Chris Wilson Fast Road Pads
Do Luck Braided Brake Lines
Wed SA-70 Wheels 9x18 and 10x18 +32 offset
Race Wheel Nuts
Tyres 295/35/18 Rear, 245/40/18 Front
Tein Coilovers and Adjustable Suspension
Cusco Front and Rear Strut Braces
Interior & ICE:
JVC KW-AVX740
Alpine front and rear speakers
Defi Control Unit, Water Temp, Boost, Oil Temp
AEM Wideband Guage
DC2 Recaro Bucket Seats, with MO BRIDE rails
Carbon Fiber Gauge Holder
Carpet Dyed Black
OEM Black Head lining and Visors
DC2 RED Recaro Seats, with Bride Rails
Exterior:
Full Genuine Ridox Body Kit.
UK Bonnet Scoop
De Wipered
De Ariel
UK Glass Headlights
6000k Knight Racer HID's
MORE PICTURES CAN BE FOUND HERE > Ridox 6 Speed Pictures Post 319 Onwards
FULL BUILD THREAD HERE > SRD Ridox 6 Speed Single Build
I will also be giving the new Owner the SRD undertray (never fitted) and New Large Lexus Oil Filter for the Car.
Few things that would need addressed. A/C needs re-gassed
No P/X and No Time wasters Please, as i've got better things to do. :D
I'll answer all question's as much as I can, so please bare with me on that one, as I might need to ask Lee things that I don't know?
PM me for my Mobile Number
Im looking for £18,000
Thanks for looking guys. :D
  • Replies 150
I hope (and I mean this in the most selfish and financially unsympathetic way possible :D) that you don't sell. Especially for some nebulous concept like "good financial management".
But if you're hell-bent on gaining some capital, I wish you the very best in selecting the most appropriate next owner :)
