Starting problem
AMG
I think this will end up getting towed to you chris.
Had a re-check of the fuses in drivers footwell. Took them all out and made sure they were fine. When I tried to start it again it did not even turn over :(
All the dash electrics came on but when I turned the key.... Nothing. Does this point to the ecu? Guessing now.
Thanks mate. I will give that a go. Going to triple check every fuse and relay too. Will double check everything else too to see if i can get the bottom of it. Sods law it will be something really simple and obvious, well, hopefully.
If you're going to be unclipping the various connectors, it would be a good idea to refill them with dielectric grease to stop them shorting.
Edited by Morpheus (see edit history)
