Thinking of going back to a stock clocks
hodge
AFAIK the TRD Tacho works out of the box, no calibration required!
We need John Hodgie, Hodgerson to do his Magic and whip up a copy! Surprised nobody has done one yet! Even just a face plate over the stock tacho with the Red and Yellow but using the normal RPM intervals
But you can get them - metal monkey dials can make you some up - can do TRD copies. The calibration of the tacho is dead easy. Run the engine until its warm, then put the needle on at 800 rpm ish. Job done.
dial is about £35 ish
-- edit --
from what I can recall there is no difference on the electronics side between a stock and TRD tacho - only difference is the needle position
Edited by heckler (see edit history)
