seba Posted January 13, 2012 Share Posted January 13, 2012 Just replaced the stock N/A manifold with an aftermarket one wich also replaces the first cat. Now the new one only has 2 holes for the upper O2 sensors but there is no hole for the third O2 sensor located on the first catpart. Would the 2 upper O2 sensors suffice or should we drill another hole for the lower one? Can't imagine going from 3 to just 2 O2 sensors is not going to affect anything Thx Quote Link to comment Share on other sites More sharing options...
barneybrendan Posted January 13, 2012 Share Posted January 13, 2012 on mine i just cable tied the third sensor up out the way ,not sure what it was actually for . Quote Link to comment Share on other sites More sharing options...
Graham1984 Posted January 13, 2012 Share Posted January 13, 2012 I thought it was a cat temp sensor. When I had my Na decatted by dude the guy there cable tied it up out of the way as if you chop it off you get warning lights come up. Quote Link to comment Share on other sites More sharing options...
barneybrendan Posted January 13, 2012 Share Posted January 13, 2012 I thought it was a cat temp sensor. When I had my Na decatted by dude the guy there cable tied it up out of the way as if you chop it off you get warning lights come up. thats right it certianly is i just couldnt remember . Quote Link to comment Share on other sites More sharing options...
Graham1984 Posted January 13, 2012 Share Posted January 13, 2012 Sadly that is as far as my knowledge stretches. Quote Link to comment Share on other sites More sharing options...
Nic Posted January 14, 2012 Share Posted January 14, 2012 (edited) The 2 upper sensors in the cast manifolds are the O2 sensors. The lower sensor in the first cat is a temperature sensor, it illuminates the dash warning light if the cat overheats, it doesn't have any effect on the performance of the car. Most just cable tie the sensor out of the way. Edited January 14, 2012 by Nic (see edit history) Quote Link to comment Share on other sites More sharing options...
seba Posted January 14, 2012 Author Share Posted January 14, 2012 Ok thank you all Quote Link to comment Share on other sites More sharing options...
