Jellybean Posted January 13, 2012 Share Posted January 13, 2012 I make out the correct offsets for my car as: Rear: 5X114.3 19X10.5J ET+12 Front: 5X114.3 19X9.5J ET +14 Would these Fit? 5 x 114.3 PCD Fronts are 18 x 11JJ Offset : +10 Rears are 18 x 13.5JJ Offset : -10 Link to comment Share on other sites More sharing options...
dive_popo Posted January 13, 2012 Share Posted January 13, 2012 I'm guessing you'll need a widebody to fit these... Link to comment Share on other sites More sharing options...
Stephendjb Posted January 13, 2012 Share Posted January 13, 2012 I'm guessing you'll need a widebody to fit these... Very much so... Link to comment Share on other sites More sharing options...
Jellybean Posted January 13, 2012 Author Share Posted January 13, 2012 Mine is a TRD Link to comment Share on other sites More sharing options...
Jamesy Posted January 13, 2012 Share Posted January 13, 2012 13.5j with a -10 offset How much wider is your car at the rear than stock?? Link to comment Share on other sites More sharing options...
Stephendjb Posted January 13, 2012 Share Posted January 13, 2012 (edited) Rears will be very nearly 5" stuck out further than your present wheels & that's on both sides not overall Edit sorry that's wrong it's about 3 & 1/2" Edited January 13, 2012 by Stephendjb (see edit history) Link to comment Share on other sites More sharing options...
Jellybean Posted January 13, 2012 Author Share Posted January 13, 2012 13.5j with a -10 offset How much wider is your car at the rear than stock?? 50mm ,not too sure if that is 25mm each side or 50mm Link to comment Share on other sites More sharing options...
Jellybean Posted January 13, 2012 Author Share Posted January 13, 2012 Rears will be very nearly 5" stuck out further than your present wheels & that's on both sides not overall Edit sorry that's wrong it's about 3 & 1/2" definetly Still room at the Front for a more agressive offset than +14 and Rears I rekon I would get away with +10 on a 10.5 rear Link to comment Share on other sites More sharing options...
Nic Posted January 13, 2012 Share Posted January 13, 2012 If you know the width and offset of your current wheels then compare any new wheels you are considering using this OFFSET CALCULATOR Link to comment Share on other sites More sharing options...
