Help with vvti harness
Guest Kmichael
Guest Kmichael
Hi Guys we are back to working on this project. Need help with vvti harness, On the harness were the mass air wires branch off main harness there are also 2 wires that go some were els 1 is a white wire with green stripe the other is a white wire with a blue stripe. its cut there and dont now were they go. At this point are engine starts right up but only idles and when given fuel stalls will not rev . Dont now if the 2 wires have anything to do with this issue but just tring to elliminate loose ends at this pointHope someone can help us thanks K
Edited by Gaz6002 (see edit history)
  • 1 month later...
Guest rpk2012
The internet has tons of information, some easy, some hard to find. Here are a few tidbits.
-http://www.supramania.com/forums/showthread.php?153102-Your-1JZ-GTE-And-2JZ-GTE-Swap-Guide-For-Dummies
- http://www.supras.nl/index.php?option=com_content&task=view&id=34&Itemid=50
- http://wilbo666.pbworks.com/w/page/37092272/Wiki%20-%20wilbo666 (Best pin outs)
Maybe with some luck these have the information you need. I know it has been like pulling teeth to get info on VVTi harness.
~Ryan
