Hello
Guest Wytse
Hello everybody. My name is Wytse I am 19 years old and i live in Belgium.
I am planning on buying a 1996 n/a supra. But i dont know anything about this simply awesome car so i could use some tips. I already found out that the clutch is a weakness. But every bit of info is most welcome.
Thanks alot.
Grtz, Wytse
The clutch will only be a problem if you change the engine or run boost on your Na engine. You should be fine for many miles, even a stock clutch can take a good hammering from the NA engine. Mine had 12 months of hard driving before I swapped it for an uprated one.
