p3te Posted January 10, 2012 Share Posted January 10, 2012 i will be getting engine parts powder coated (IC pipes, manifold, throttle body, cam covers, top water neck, turbo pipes) and was wondering would the heat effect the internals of any of the parts, mainly this pipe (see pic) now i know the turbo pipes get hot anyway but is there anything inside that could be damaged from being baked 200 degrees in an oven? Same goes for the internals of the throttle body and cam covers? [ATTACH=CONFIG]144143[/ATTACH] Link to comment Share on other sites More sharing options...
Rob Posted January 11, 2012 Share Posted January 11, 2012 IIRC, all the tiny coil springs and plastic bits of the TB are outside, so you'd have removed them anyway. Whats in that box? as if you PPC it the nuts will be coated in place. Link to comment Share on other sites More sharing options...
hodge Posted January 11, 2012 Share Posted January 11, 2012 I had all Johnny.Gs engine parts powder coated black when I did his big twin build and he's had no issues with heat effecting it at all. Link to comment Share on other sites More sharing options...
p3te Posted January 11, 2012 Author Share Posted January 11, 2012 IIRC, all the tiny coil springs and plastic bits of the TB are outside, so you'd have removed them anyway. Whats in that box? as if you PPC it the nuts will be coated in place. thats onother thing, if i powder coat this it will be sealed in then lol im not sure whats inside Link to comment Share on other sites More sharing options...
