powder coating engine parts
p3te
i will be getting engine parts powder coated (IC pipes, manifold, throttle body, cam covers, top water neck, turbo pipes) and was wondering would the heat effect the internals of any of the parts, mainly this pipe (see pic) now i know the turbo pipes get hot anyway but is there anything inside that could be damaged from being baked 200 degrees in an oven? Same goes for the internals of the throttle body and cam covers?
[ATTACH=CONFIG]144143[/ATTACH]
IIRC, all the tiny coil springs and plastic bits of the TB are outside, so you'd have removed them anyway. Whats in that box? as if you PPC it the nuts will be coated in place.
thats onother thing, if i powder coat this it will be sealed in then lol im not sure whats inside
