mikeyh Posted January 10, 2012 Share Posted January 10, 2012 just the intake not the throttle body etc http://img94.imageshack.us/img94/7216/016ayh.jpg Uploaded with ImageShack.us http://img818.imageshack.us/img818/7169/017qf.jpg Uploaded with ImageShack.us £80 Link to comment Share on other sites More sharing options...
Dim Sum Posted January 10, 2012 Share Posted January 10, 2012 Is this a UK Spec or Jap? Link to comment Share on other sites More sharing options...
mikeyh Posted January 11, 2012 Author Share Posted January 11, 2012 mine is a j spec i think, what is the difference? Link to comment Share on other sites More sharing options...
Dim Sum Posted January 12, 2012 Share Posted January 12, 2012 There is a difference I was told but I can't remember what the difference is ........ Link to comment Share on other sites More sharing options...
mikeyh Posted January 12, 2012 Author Share Posted January 12, 2012 maybe sombody can shed some light on this, if i know the difference ill check it tommorow:D Link to comment Share on other sites More sharing options...
Rob W Posted January 12, 2012 Share Posted January 12, 2012 uk spec have the egr ports on the back/side. You can get plates to block them off tho. Link to comment Share on other sites More sharing options...
mikeyh Posted January 14, 2012 Author Share Posted January 14, 2012 mine looks to have been blanked off http://img683.imageshack.us/img683/7027/005bkk.jpg Uploaded with ImageShack.us Link to comment Share on other sites More sharing options...
Dim Sum Posted January 15, 2012 Share Posted January 15, 2012 mine looks to have been blanked off http://img683.imageshack.us/img683/7027/005bkk.jpg Uploaded with ImageShack.us I have a UK spec, and if you can confirm that it fit, and its a straight forward swap i take it. Link to comment Share on other sites More sharing options...
mikeyh Posted January 16, 2012 Author Share Posted January 16, 2012 i cant confirm this will fit yours its probably best you do your own homework;) or maybe other members can confirm this for you:cool: Link to comment Share on other sites More sharing options...
Scott Posted January 16, 2012 Share Posted January 16, 2012 It's a Jspec, won't fit UK spec. Link to comment Share on other sites More sharing options...
mikeyh Posted January 16, 2012 Author Share Posted January 16, 2012 It's a Jspec, won't fit UK spec. what is the difference? Link to comment Share on other sites More sharing options...
Scott Posted January 16, 2012 Share Posted January 16, 2012 what is the difference? EGR ports. If the UK owner wants to get rid of their EGR valve then I guess they could go down that route. Not sure on how viable that is though. Link to comment Share on other sites More sharing options...
mikeyh Posted January 16, 2012 Author Share Posted January 16, 2012 arn't my ports just blocked off cant these be removed and then egr valves fitted? Link to comment Share on other sites More sharing options...
Scott Posted January 16, 2012 Share Posted January 16, 2012 arn't my ports just blocked off cant these be removed and then egr valves fitted? The EGR port doesn't exist on your manifold bud. It's not one of the caps, it goes above that area IIRC. You can spot a UK spec manifold easily as the casting line is off centre. Link to comment Share on other sites More sharing options...
mikeyh Posted January 16, 2012 Author Share Posted January 16, 2012 haha shows what i know about the uk spec thanks for the info Link to comment Share on other sites More sharing options...
mikeyh Posted January 28, 2012 Author Share Posted January 28, 2012 Link to comment Share on other sites More sharing options...
Dim Sum Posted January 29, 2012 Share Posted January 29, 2012 The EGR port doesn't exist on your manifold bud. It's not one of the caps, it goes above that area IIRC. You can spot a UK spec manifold easily as the casting line is off centre. Thanks for the information. Might have to get you on speed dial, Scott Link to comment Share on other sites More sharing options...
mikeyh Posted February 12, 2012 Author Share Posted February 12, 2012 does nobody fancy this? Link to comment Share on other sites More sharing options...
mikeyh Posted February 19, 2012 Author Share Posted February 19, 2012 Bump Link to comment Share on other sites More sharing options...
mikeyh Posted February 27, 2012 Author Share Posted February 27, 2012 back to the top Link to comment Share on other sites More sharing options...
mikeyh Posted March 5, 2012 Author Share Posted March 5, 2012 offers Link to comment Share on other sites More sharing options...
mikeyh Posted April 30, 2012 Author Share Posted April 30, 2012 still got this Link to comment Share on other sites More sharing options...
ashbuster Posted April 30, 2012 Share Posted April 30, 2012 dont know why this hasnt gone wouldnt polishing alone cost more than £80? Link to comment Share on other sites More sharing options...
Guest suprageek Posted April 30, 2012 Share Posted April 30, 2012 will u throw the tv in Link to comment Share on other sites More sharing options...
mikeyh Posted May 9, 2012 Author Share Posted May 9, 2012 Icyh clear ur pm's. Manifold left this morning can u leave some feedback when u receive it please Link to comment Share on other sites More sharing options...
