Guest witch636 Posted January 9, 2012 Share Posted January 9, 2012 hi, every so often i am experiencing a very loud noise for about 10 seconds, it sounds a bit like when you run your finger around the top of a wine glass. its not a constant noise and doesnt happen every single time the car is used but when it does happen it sounds awful. is it possible it could have something to do with brake pads even though they were changed not too long ago. any other suggestions would be greatly appreciated as i have no clue Quote Link to comment Share on other sites More sharing options...
tkddav3 Posted January 9, 2012 Share Posted January 9, 2012 well if you think its the pads, does it only happen when youve got your foot on the anchors? oh and welcome Quote Link to comment Share on other sites More sharing options...
Supra N_A Posted January 9, 2012 Share Posted January 9, 2012 funny enough this is happening to me which i think its the front driverside brake pads may just need copper greased up..... also it screeches then when I brake it screeches again and stops so defo brake related when car gets new exhaust system fitted there having a look for me but will let you kno if its that sure it is thow! Quote Link to comment Share on other sites More sharing options...
Guest witch636 Posted January 9, 2012 Share Posted January 9, 2012 if i apply pressure to the brakes the noise stops and then starts again when i let off the brakes. Quote Link to comment Share on other sites More sharing options...
Guest witch636 Posted January 9, 2012 Share Posted January 9, 2012 hi, ive had the same was suggested to me. unfortunately i dont know much about mechanical stuff and have never changed the pads or anything else myself so im not too sure exactly where i should be putting the copper grease Quote Link to comment Share on other sites More sharing options...
Guest witch636 Posted January 9, 2012 Share Posted January 9, 2012 oh thanks for the welcome, im not too sure how to use this site which is why i never have but must be doing something right to get a reply:) Quote Link to comment Share on other sites More sharing options...
Dnk Posted January 9, 2012 Share Posted January 9, 2012 Find a good local garage to have a look for you, ask your mates etc to recommend somewhere. If you dont know what your doing brakes are best left to someone who does. Quote Link to comment Share on other sites More sharing options...
Guest witch636 Posted January 9, 2012 Share Posted January 9, 2012 thanks, yes im sure your right. ive always been lucky to have someone help in the past but it would be good to try and sort the problem myself if possible and try to learn, i dont have the confidence completely by myself so though it would do no harm to ask and see Quote Link to comment Share on other sites More sharing options...
Dnk Posted January 9, 2012 Share Posted January 9, 2012 Maybe a local member with a good enough knowledge could help you with this then. It might be a bit more involved than just putting some copper slip on the pads etc though so worth getting them checked over properly, i'd be inclined to have all four calipers looked at closely as their showing their age now. Unless they've been rebuilt they could be in need of stripping and refurbing or even replacing. Quote Link to comment Share on other sites More sharing options...
Guest witch636 Posted January 9, 2012 Share Posted January 9, 2012 ok thanks for your advice Quote Link to comment Share on other sites More sharing options...
straightsix Posted January 9, 2012 Share Posted January 9, 2012 Where in Cheshire are you bud? You could bring it over and I'll take a look for you if you like. I'm near Nantwich. PM me if you need to. Scott Quote Link to comment Share on other sites More sharing options...
mellonman Posted January 10, 2012 Share Posted January 10, 2012 crank pulley ftw search tipex test ,wouldnt hurt just to test Quote Link to comment Share on other sites More sharing options...
Dnk Posted January 10, 2012 Share Posted January 10, 2012 Im also thinking this could be a wheel bearing on its way out so i'd recommend you get it checked asap. Can you jack the car up as though your changing a wheel ? if so jack up the wheel causing the noise then hold the wheel at 9 and 3 (clock face) and try to rock the wheel and feel for any play, do the same at 12 and 6, then spin the wheel by hand and listen for noise from the center area where the wheel nuts are Quote Link to comment Share on other sites More sharing options...
