Noz Posted January 9, 2012 Share Posted January 9, 2012 Would it be possible to put JSpec Supra brakes onto an MR2, my mrs needs a new caliper, and Im swapping mine for some UK fronts soon and it just doesn't seem sense for her to buy bran new when I will have a set lying about. Thanks Quote Link to comment Share on other sites More sharing options...
abtin90 Posted January 9, 2012 Share Posted January 9, 2012 Also interested in finding out the same as my brother has an mr2 and is looking to get new brakes and I'll have a set of spare jspecs once I get hold of a set of uk brakes. Quote Link to comment Share on other sites More sharing options...
Scott Posted January 10, 2012 Share Posted January 10, 2012 I asked this and I was told no. I didn't take it any further than this. I'm guessing they could be made to fit but my question was more regarding a straight swap. Quote Link to comment Share on other sites More sharing options...
j_jza80 Posted January 10, 2012 Share Posted January 10, 2012 I would tread very carefully when altering the brake balance on an MR2. Quote Link to comment Share on other sites More sharing options...
abtin90 Posted January 11, 2012 Share Posted January 11, 2012 I was hoping they'd be a straight swap, guess ill have to start looking for some mr2 brakes. Thanks for the advice. Quote Link to comment Share on other sites More sharing options...
straightsix Posted January 11, 2012 Share Posted January 11, 2012 Which caliper do you need? There's 3 MR2's in the breakers yard local to me - could have a look next time I'm there if you like? PM me to give me a heads up if you do Quote Link to comment Share on other sites More sharing options...
barneybrendan Posted January 11, 2012 Share Posted January 11, 2012 im sure the celica breaker down our way will have loads on the shelf aswell if you get stuck Quote Link to comment Share on other sites More sharing options...
j_jza80 Posted January 11, 2012 Share Posted January 11, 2012 Another way might be either Lexus LS400 4 pots or Celica GT4 ones (though these are more likely to be an easier swap, they'll also be more expensive) However, as I said be careful when fitting different brakes to those, MR2s are notorious for swapping ends if you overcook it into a bend and have to slow down quickly as standard, upsetting the brake balance is likely to make this worse. I'd speak to someone like Chris Wilson before proceeding. Quote Link to comment Share on other sites More sharing options...
