Guest Jaydutch Posted January 9, 2012 Share Posted January 9, 2012 Hey guys, i got under my car today because the peice of plastic under the engine was hanging down and scraping speed bumps. much to my suprise i find this sitting on the plasic! well you can see where it has come from...... any1 had anything like this before? any advice or info much apreciated Link to comment Share on other sites More sharing options...
barneybrendan Posted January 9, 2012 Share Posted January 9, 2012 common problem,fix= new crank pulley Link to comment Share on other sites More sharing options...
Tricky-Ricky Posted January 9, 2012 Share Posted January 9, 2012 Common problem, get yourself a new/SH pulley, or aftermarket damped type, and obviously don't drive it. Link to comment Share on other sites More sharing options...
fastcar Posted January 9, 2012 Share Posted January 9, 2012 I have heard of the bottom pulley coming off before but the oil pump pulley. I would do the tip ex test on the bottom pulley to as I should think that would not far from going ether Link to comment Share on other sites More sharing options...
Guest Jaydutch Posted January 9, 2012 Share Posted January 9, 2012 i dont know what im talking about the oil pump pulley was a guess, its right in the middle of the engine block and its the lowest pulley Link to comment Share on other sites More sharing options...
barneybrendan Posted January 9, 2012 Share Posted January 9, 2012 (edited) it the crank pulley ,te rubber gives out which is why it has come off. you are not the only one this has happend to http://www.mkivsupra.net/vbb/showthread.php?210935-My-crank-pulley-just-failed-(&highlight=crank+pulley+broken Edited January 9, 2012 by barneybrendan (see edit history) Link to comment Share on other sites More sharing options...
Guest Jaydutch Posted January 9, 2012 Share Posted January 9, 2012 cheers barney how the belt stayed on and i didnt even know it had happend is beyond me. good job the plastic was hanging down!! i live around the corner from toyota so was considering having it done there. any idea what a reasonable price to do this would be? i think id want a new belt seeing as this 1 could have been twisted like that for many miles Link to comment Share on other sites More sharing options...
fastcar Posted January 9, 2012 Share Posted January 9, 2012 i dont know what im talking about the oil pump pulley was a guess, its right in the middle of the engine block and its the lowest pulley Have a look at titan Motorsport website they do a solid bottom crank pulley a lot stronger then stock could be an option to safeguard this from happening again if your planning on keeping the supra for a long time or upgrading the power Link to comment Share on other sites More sharing options...
Guest Jaydutch Posted January 9, 2012 Share Posted January 9, 2012 the titan 1 is around £300, my brakes need sorting pretty quickly as well so im sad to say il be taking the cheap option thanks though Link to comment Share on other sites More sharing options...
Tricky-Ricky Posted January 9, 2012 Share Posted January 9, 2012 Have a look at titan Motorsport website they do a solid bottom crank pulley a lot stronger then stock could be an option to safeguard this from happening again if your planning on keeping the supra for a long time or upgrading the power A solid pulley is not a good idea, they are damped for a very good reason. Link to comment Share on other sites More sharing options...
Guest Jaydutch Posted January 9, 2012 Share Posted January 9, 2012 might be a silly question but would this have affected performance? when i started it from cold the over evening it felt like it choked a bit at half throttle at 3 thousand revs... related? Link to comment Share on other sites More sharing options...
fastcar Posted January 9, 2012 Share Posted January 9, 2012 the titan 1 is around £300, my brakes need sorting pretty quickly as well so im sad to say il be taking the cheap option thanks though Didn't know they where that much! Best be going with stock one then:) Link to comment Share on other sites More sharing options...
fastcar Posted January 9, 2012 Share Posted January 9, 2012 might be a silly question but would this have affected performance? when i started it from cold the over evening it felt like it choked a bit at half throttle at 3 thousand revs... related? Could be I would think the alternator wouldn't be working properly if the belt was lose Link to comment Share on other sites More sharing options...
Geo Posted January 9, 2012 Share Posted January 9, 2012 the titan 1 is around £300, my brakes need sorting pretty quickly as well so im sad to say il be taking the cheap option thanks though stock crank pulley is your best option here. They are roughly the same price £300 delivered. Got mine off whifbitz when Lee did my Build Link to comment Share on other sites More sharing options...
Paul Whiffin Posted January 10, 2012 Share Posted January 10, 2012 Just so you all know, I sell my own full dampened crank pulley for the Supra now, see here http://whifbitzperformancetuning.co.uk/toyota-supra-supra-engine-components-camshafts-pulleys-belts-garage-whifbitz-p-5968.html you cant tell them apart from the genuine items, been fully tested for over a year now. Link to comment Share on other sites More sharing options...
Scott Posted January 10, 2012 Share Posted January 10, 2012 Somethings not right here. Those belts look miles off (look at the twist that's been put in it to keep it on). IMO that pulley has went with the previous owner and they have thrown it back together quickly then gotten rid. You're VERY lucky that it's OK. Link to comment Share on other sites More sharing options...
Guest Jaydutch Posted January 11, 2012 Share Posted January 11, 2012 had 1 of whifbits pulleys put on today toyota garage wanted £650 haha! and scott the belt was changed a few months back and it was fine. it twisted like that when the outer ring came off the pulley! thanks for help and advice guys Link to comment Share on other sites More sharing options...
Scott Posted January 11, 2012 Share Posted January 11, 2012 had 1 of whifbits pulleys put on today toyota garage wanted £650 haha! and scott the belt was changed a few months back and it was fine. it twisted like that when the outer ring came off the pulley! thanks for help and advice guys That's very strange then as I can see no way that the belt can come off and twist the way that it has. If it had twisted the other way then that could be explained but it's actually turned in the way, something that I can't see happening on its own. Link to comment Share on other sites More sharing options...
Guest Jaydutch Posted January 11, 2012 Share Posted January 11, 2012 i know lol its shocking how it twisted in that direction??? but the new belt was on there nicely a few months back its a mystery! Link to comment Share on other sites More sharing options...
