Neil-NA Posted January 8, 2012 Share Posted January 8, 2012 Looking at softening my rear end Does anyone know if the UK TT spring rates are lower than an NAs spring rate? I am sure I read the UKs had softer springs than jspecs but that may well only apply to the TT. Quote Link to comment Share on other sites More sharing options...
Abz Posted January 8, 2012 Share Posted January 8, 2012 Looking at softening my rear end PM Ed, he will sort you out I read that too, they are softer so in theory should have. My springs are way too soft! Quote Link to comment Share on other sites More sharing options...
Neil-NA Posted January 8, 2012 Author Share Posted January 8, 2012 I read that too, they are softer so in theory should have. My springs are way too soft! I take it you are still on stock NA springs? I found stock NA springs soft then the tein NA springs way too hard, but i want to go even softer now if thats what the UK TT springs will offer. Quote Link to comment Share on other sites More sharing options...
Abz Posted January 8, 2012 Share Posted January 8, 2012 I take it you are still on stock NA springs? I found stock NA springs soft then the tein NA springs way too hard, but i want to go even softer now if thats what the UK TT springs will offer. So you want even softer than the NA springs? Do you want my mattress? Quote Link to comment Share on other sites More sharing options...
Neil-NA Posted January 8, 2012 Author Share Posted January 8, 2012 So you want even softer than the NA springs? Do you want my mattress? Aslong as its not full of man stains I only want them to go on my spare rear shocks for when at the strip. Quote Link to comment Share on other sites More sharing options...
Abz Posted January 8, 2012 Share Posted January 8, 2012 Aslong as its not full of man stains I only want them to go on my spare rear shocks for when at the strip. Well, guess you can't then! Ah, hopefully CW will be along to confirm then. Quote Link to comment Share on other sites More sharing options...
SteveC Posted January 9, 2012 Share Posted January 9, 2012 I can tell you that a set of UK rear springs will raise the back end around 10mm over a set of J-Spec TT rear springs. Can't say that I found the J-Specs much firmer though. I don't know for certain, but I doubt there's much difference between J-Spec N/A and TT rear springs. Quote Link to comment Share on other sites More sharing options...
Neil-NA Posted January 9, 2012 Author Share Posted January 9, 2012 I can tell you that a set of UK rear springs will raise the back end around 10mm over a set of J-Spec TT rear springs. Can't say that I found the J-Specs much firmer though. I don't know for certain, but I doubt there's much difference between J-Spec N/A and TT rear springs. Thanks for the info bud, i might just take a gamble and get some, if that doesn't work i will have to get some made. Quote Link to comment Share on other sites More sharing options...
Chris Wilson Posted January 9, 2012 Share Posted January 9, 2012 Spring rate difference is minor, and probably unnoticeable, ride height apart. Quote Link to comment Share on other sites More sharing options...
