Graham1984 Posted January 7, 2012 Share Posted January 7, 2012 Had a look around and couldn't find a answer (Sorry if there is one) but is there any set way to check the inlet valve is opening correctly or even a cleaning option just if it is getting stuck, Possibly a retarded question but seeing as my knowledge is based around car needs petrol,insurance and tax and that I know sod all else I feel justified asking. Quote Link to comment Share on other sites More sharing options...
barneybrendan Posted January 8, 2012 Share Posted January 8, 2012 if its working you will feel a kick at a certain rpm cant remember what that is now . Quote Link to comment Share on other sites More sharing options...
Swampy442 Posted January 8, 2012 Share Posted January 8, 2012 The idle control valve? Quote Link to comment Share on other sites More sharing options...
Noz Posted January 8, 2012 Share Posted January 8, 2012 Valve that remains closed to enable low down torque. DavidP knows about this as he removed his so im sure he would know about cleaning it. But my first protocol would be a god service then dyno. Quote Link to comment Share on other sites More sharing options...
Graham1984 Posted January 8, 2012 Author Share Posted January 8, 2012 There is still the kick at around 4.5k rmp but It still feel somewhat less sharp and delayed, I thought I would just check to see if there was any dirt or usual crap making it stick. I changed the spark plugs and oil /filter the other day and will have to change the air/fuel filter as soon as I can but was just wondering if there was anything else worth checking. Quote Link to comment Share on other sites More sharing options...
David P Posted January 8, 2012 Share Posted January 8, 2012 (edited) Gently rev the engine and watch, you will see if it is working or not. Edited January 8, 2012 by David P (see edit history) Quote Link to comment Share on other sites More sharing options...
Chris Wilson Posted January 8, 2012 Share Posted January 8, 2012 Stick a piece of card under the stop screw and see if it falls out on a run, or do something more elegant with a piece of stiff wire and a sliding ring that moves along the wire, but stays put when the valve closes again, so you can see it's fully opening. Best is watch it on a rolling road pull. Quote Link to comment Share on other sites More sharing options...
