Axle Posted January 6, 2012 Share Posted January 6, 2012 I have no need for this as I am going for the Syvecs. It is only the Boost controller so will need the solenoid. I will get a pic up if its makes a difference but it is very good condition and was barely used. Just like the one pictured in this link http://www.part-box.com/product_info.php?products_id=42732 £150 delivered. Link to comment Share on other sites More sharing options...
little num Posted January 6, 2012 Share Posted January 6, 2012 I have the correct dual solanoid for this kit so can be added to make it a full kit for £60 posted. Link to comment Share on other sites More sharing options...
Axle Posted January 10, 2012 Author Share Posted January 10, 2012 I believe Lilnum has all the wiring to it to be fitted straight on with my Boost controller. So as it stands £210 in all delivered. Link to comment Share on other sites More sharing options...
little num Posted January 12, 2012 Share Posted January 12, 2012 Ill do the solanoid for £50 posted so the full kit is £200 posted, and imo a total bargain. Link to comment Share on other sites More sharing options...
Axle Posted January 12, 2012 Author Share Posted January 12, 2012 Serious Bargain.. SOLD The Spec R features a dual solenoid that diverts pressure away from the turbo actuator to achieve higher boost. This dual solenoid is linked to a smart control unit installed inside the car, which allows you to control the boost pressure. The control unit also displays live boost pressure. The Spec R unit has four user programmable boost settings. Scramble and gain settings are programmeable. There is a boost warning mode, which can be pre set to visually and audibly alert the driver to an overboost situation. The unit can also be programmed to reduce the solenoid duty cycle in an overboost situation. It is suitable for both internal and external wastegate applications. The Spec R can control up to 2.5 bar of boost Link to comment Share on other sites More sharing options...
tooquicktostop Posted January 12, 2012 Share Posted January 12, 2012 whats the reduced price with everything required please Link to comment Share on other sites More sharing options...
Axle Posted January 13, 2012 Author Share Posted January 13, 2012 Full price with everything required is £200 delivered. Link to comment Share on other sites More sharing options...
tooquicktostop Posted January 13, 2012 Share Posted January 13, 2012 Willing to take £325 for this and the cam pulleys ? Link to comment Share on other sites More sharing options...
Axle Posted January 13, 2012 Author Share Posted January 13, 2012 Already have offers on cams, will let you know outcome. Link to comment Share on other sites More sharing options...
tooquicktostop Posted January 13, 2012 Share Posted January 13, 2012 Ok, I have cash waiting Link to comment Share on other sites More sharing options...
Axle Posted January 13, 2012 Author Share Posted January 13, 2012 Sold Link to comment Share on other sites More sharing options...
