johnny g Posted March 19, 2012 Share Posted March 19, 2012 They slept together last night. http://i30.photobucket.com/albums/c338/jamie450x/cdcc9abb.jpg Ahh ... Not seen it for a while. Link to comment Share on other sites More sharing options...
Rob_Mitchell Posted March 19, 2012 Share Posted March 19, 2012 I wish mine was in that room, looks fun, mines lonely... Link to comment Share on other sites More sharing options...
johnny g Posted March 19, 2012 Share Posted March 19, 2012 Sod the SnapOn cover, I want the curtains behind Jamie's car. Link to comment Share on other sites More sharing options...
Geo Posted March 19, 2012 Share Posted March 19, 2012 WOW! I think lee must be using the force, that is some fast work right there. Love these updates, short, fast and pic heavy Link to comment Share on other sites More sharing options...
SteveR Posted March 20, 2012 Share Posted March 20, 2012 Compression will be slightly higher now... Was the old gasket thicker than 1.2mm or do I misunderstand how the compression will rise? Link to comment Share on other sites More sharing options...
JamieP Posted March 20, 2012 Author Share Posted March 20, 2012 Was the old gasket thicker than 1.2mm or do I misunderstand how the compression will rise? I was on oem 1.4mm gasket, now on HKS 1.2 and slight head skim. Link to comment Share on other sites More sharing options...
SteveR Posted March 20, 2012 Share Posted March 20, 2012 I was on oem 1.4mm gasket, now on HKS 1.2 and slight head skim. I didn't realise the OEM was quite as thick as that. Of course, the skim will also have an impact - duh, I've not woken up yet. Remap required or is it not likely to be significant enough a difference / or is it within the ECU's fine-tuning range without too much bother? Link to comment Share on other sites More sharing options...
JamieP Posted March 20, 2012 Author Share Posted March 20, 2012 Yeah the map will need checking, Ryan needs to put all the latest firmware upgrades on anyhow, it's not been upgraded in a few months. Link to comment Share on other sites More sharing options...
supra matt Posted March 20, 2012 Share Posted March 20, 2012 Will smaller gasket plus head skim turn your engine into an interfereance one Jamie ? Link to comment Share on other sites More sharing options...
JamieP Posted March 20, 2012 Author Share Posted March 20, 2012 I think it always has been with the big cams. Link to comment Share on other sites More sharing options...
JamieP Posted March 20, 2012 Author Share Posted March 20, 2012 Block cleaned up. Head crack tested and skimmed, 7 thou removed. L19 studs installed, they get torqued to 13ftlb. Head back on with hks gasket, torqued down to 95ftlb. Link to comment Share on other sites More sharing options...
JamieP Posted March 20, 2012 Author Share Posted March 20, 2012 Not bad considering Lee only started taking it apart yesterday Link to comment Share on other sites More sharing options...
Josh Posted March 20, 2012 Share Posted March 20, 2012 Not bad considering Lee only started taking it apart yesterday Very good job indeed. Good updates Link to comment Share on other sites More sharing options...
johnny g Posted March 20, 2012 Share Posted March 20, 2012 He's tested fitting the L19's on yours before mine. Result Quick work though! Link to comment Share on other sites More sharing options...
MONKEYmark Posted March 21, 2012 Share Posted March 21, 2012 Amazing car and work by Lee and ryan they have a great reputation.love seeing all work you have done to your car.great inspiration keep it up Jamie Link to comment Share on other sites More sharing options...
Ricky49 Posted March 21, 2012 Share Posted March 21, 2012 Fast work as usual by the Perryman, he's like a machine. Are you fitting a new turbo this visit mate. Link to comment Share on other sites More sharing options...
Guest j2x Posted March 21, 2012 Share Posted March 21, 2012 you may find you need a little more than 95lb i erred on the side of caution with a similar figure when installing L19 on mine as i didnt want to pull the block out of round too much, but it was pressurising the coolant a bit on the dyno with a 4708 on 29psi so i retorqued them all up to 105ftlb with the moly lube and that fixed it Link to comment Share on other sites More sharing options...
JamieP Posted March 21, 2012 Author Share Posted March 21, 2012 Really, Nero at Titan said to go 90ftlb, I said to Lee to do them to 95. 105ftlb sounds loads. Link to comment Share on other sites More sharing options...
Guest j2x Posted March 21, 2012 Share Posted March 21, 2012 yeah as mentioned i thought 95lb to be a good starting point too. when i decided to tighten them after it pressurised at 95lb i only planned to go to 100, but when i was going around the studs, two were a bit looser than the rest so i ended up going around again and went a little over. actually when it first pushed into the coolant it was on 27psi but its since been retuned on 29 and has subsequently held fine see how it goes for you. maybe cylinder pressure is less and it will cope. i think both our cars trap 150ish though?.. thats why i thought i would pipe up sorry about double post above, mod pls delete Link to comment Share on other sites More sharing options...
JamieP Posted March 21, 2012 Author Share Posted March 21, 2012 Ok thanks for the advice, luckily the cams are not in yet, I just told lee to torque it down to 105ftlb, I found a thread on supraforum and 105 is what ARP say to torque it to as well. Link to comment Share on other sites More sharing options...
Brazil Posted March 21, 2012 Share Posted March 21, 2012 Ok thanks for the advice, luckily the cams are not in yet, I just told lee to torque it down to 105ftlb, I found a thread on supraforum and 105 is what ARP say to torque it to as well. That was a close call, I bet you are glad the man dropped in your thread when he did..! Link to comment Share on other sites More sharing options...
Rob_Mitchell Posted March 21, 2012 Share Posted March 21, 2012 Not bad considering Lee only started taking it apart yesterday Very fast and is good, as your holding me and johnny up See this beast and yourself sunday mate! Link to comment Share on other sites More sharing options...
JamieP Posted March 21, 2012 Author Share Posted March 21, 2012 That was a close call, I bet you are glad the man dropped in your thread when he did..! I read a lot of threads on the L19's and all the yanks seem to torque them between 90-95ftlb but arp say you can go up to 105, it's nice to hear from other owners though so I've gone with the same as j2x has to be on the safe side, don't fancy pulling the cams again. Link to comment Share on other sites More sharing options...
Guest j2x Posted March 21, 2012 Share Posted March 21, 2012 49psi on an 88mm plus 175 spray .... wonder what torque his head studs are at? .. sw's old car built back in the day so mightve been built with 1/2" before they even made the 7/16 i just hope im not steering you wrong. not sure what could be amiss though, im not a mechanic but the surfaces were true and i used the factory pattern and supplied moly lube. just offering my info. .. don't fancy pulling the cams again.why.. its only the fan, radiator, all the belts, cam covers, cam caps and cams that have to come off Link to comment Share on other sites More sharing options...
JamieP Posted March 23, 2012 Author Share Posted March 23, 2012 Its all back up and running, picking it up in the morning, i cant use any boost till Ryan has remapped it so im not sure i will bring it to the Austec meet yet. Link to comment Share on other sites More sharing options...
