JamieP Posted July 5, 2012 Author Share Posted July 5, 2012 safcdixon said: what is it, is the spool not as instant as you had hoped for? Spool is not as good as i had hoped but i can live with that, bit disappointed that the turbo max'd at 2 bar, might try a divided 67 and hope it will take more boost. Gotta love the syvecs, putting me in limp mode today saved my engine i bet. Link to comment Share on other sites More sharing options...
johnny g Posted July 5, 2012 Share Posted July 5, 2012 JamieP said: Spool is not as good as i had hoped but i can live with that, bit disappointed that the turbo max'd at 2 bar, might try a divided 67 and hope it will take more boost. Jamie, have you tried Owen Developments to see if they can supply a turbo to your requirements? Lee Owen sat and listened to me about what I wanted - and boost to run etc. They can make you pretty much anything you fancy. Link to comment Share on other sites More sharing options...
JamieP Posted July 5, 2012 Author Share Posted July 5, 2012 johnny g said: Jamie, have you tried Owen Developments to see if they can supply a turbo to your requirements? Lee Owen sat and listened to me about what I wanted - and boost to run etc. They can make you pretty much anything you fancy. I emailed them a while back and they said they cant do me a new hotside in the spec i want. Link to comment Share on other sites More sharing options...
dandan Posted July 5, 2012 Share Posted July 5, 2012 Without wanting to state the obvious (granny sucking eggs and all that.....) - the boost is only really a measure of how restrictive the whole engine related system is. If you put that turbo on a non ported head, with smaller valves, milder cams, or a crappy manifold or smaller exhaust you would probably see more boost. You would make less power though. What power did you expect or, what power were you told this turbo was capable of? I wouldn't give the boost any thought at all if it's making the power it should. Link to comment Share on other sites More sharing options...
JamieP Posted July 5, 2012 Author Share Posted July 5, 2012 dandan said: Without wanting to state the obvious (granny sucking eggs and all that.....) - the boost is only really a measure of how restrictive the whole engine related system is. If you put that turbo on a non ported head, with smaller valves, milder cams, or a crappy manifold or smaller exhaust you would probably see more boost. You would make less power though. What power did you expect or, what power were you told this turbo was capable of? I wouldn't give the boost any thought at all if it's making the power it should. Yeah i know you are right, turbo is rated to 985bhp so its doing as it should. http://www.precisionturbo.net/Street-and-Race/ss/800-1-000HP/details/Street-and-Race-Turbocharger---PT7175-CEA%C2%AE/273 Link to comment Share on other sites More sharing options...
Pulley Posted July 5, 2012 Share Posted July 5, 2012 You could run an intercooler bypass (boost regulated bypass under .5bar) removes lag then opens to allow fullflow and cooling when needed Ideally a divided hotside running quickspool valve to increase velocity initially Custom built hotside one-off or modified would be scary expensive Link to comment Share on other sites More sharing options...
pedrosixfour Posted July 5, 2012 Share Posted July 5, 2012 dandan said: the boost is only really a measure of how restrictive the whole engine related system is. If you put that turbo on a non ported head, with smaller valves, milder cams, or a crappy manifold or smaller exhaust you would probably see more boost. You would make less power though. That was the explanation/theory I was coming up with too but I couldn't have worded it as sweetly. And because i know S.F.A. about these things I thought it best to keep my mouth shut. Link to comment Share on other sites More sharing options...
Kirk Posted July 5, 2012 Share Posted July 5, 2012 pedrosixfour said: That was the explanation/theory I was coming up with too but I couldn't have worded it as sweetly. And because i know S.F.A. about these things I thought it best to keep my mouth shut. Admit it D, it wasn't what you was thinking at all Link to comment Share on other sites More sharing options...
pedrosixfour Posted July 5, 2012 Share Posted July 5, 2012 Kirk said: Admit it D, it wasn't what you was thinking at all Alright, I was thinking about messing with the tension in your wastegate and how I'd like to send YOU home in limp mode. Link to comment Share on other sites More sharing options...
scoooby slayer Posted July 5, 2012 Share Posted July 5, 2012 nice result jamie, what rpm are you making full boost or top of the start of the torque curve ? Link to comment Share on other sites More sharing options...
JamieP Posted July 5, 2012 Author Share Posted July 5, 2012 Its making full boost about 4200-4300 rpm id say, just been out again to see if it would go in limp mode and it seems fine, maybe it was just a bit low on fuel and the top pump overheated? Im not unhappy with it, still feels blooming fast, good news is there is no vibration at speed so must have been the prop. Link to comment Share on other sites More sharing options...
skippyboyo1 Posted July 5, 2012 Share Posted July 5, 2012 JamieP said: Its making full boost about 4200-4300 rpm id say, just been out again to see if it would go in limp mode and it seems fine, maybe it was just a bit low on fuel and the top pump overheated? Im not unhappy with it, still feels blooming fast, good news is there is no vibration at speed so must have been the prop. Does this mean she's running at pod now then? Link to comment Share on other sites More sharing options...
JamieP Posted July 5, 2012 Author Share Posted July 5, 2012 (edited) skippyboyo1 said: Does this mean she's running at pod now then? Ive not made my mind up yet, im worried about breaking the stock prop tbh. Edited July 5, 2012 by JamieP (see edit history) Link to comment Share on other sites More sharing options...
scotty71 Posted July 5, 2012 Share Posted July 5, 2012 skippyboyo1 said: Does this mean she's running at pod now then? Jamie would have a cold sweat on his brow not running Link to comment Share on other sites More sharing options...
Kirk Posted July 5, 2012 Share Posted July 5, 2012 Have you already sent the knackered prop back? If not just bring that with you and swap it over at the pod. Link to comment Share on other sites More sharing options...
scoooby slayer Posted July 5, 2012 Share Posted July 5, 2012 JamieP said: Its making full boost about 4200-4300 rpm id say, just been out again to see if it would go in limp mode and it seems fine, maybe it was just a bit low on fuel and the top pump overheated? Im not unhappy with it, still feels blooming fast, good news is there is no vibration at speed so must have been the prop. whatever way you look at it fella still a 1000 hp car, and 4200 rpm is a good improvement from the last dyno graph i saw, wheres ur redline ? Link to comment Share on other sites More sharing options...
Littler Posted July 5, 2012 Share Posted July 5, 2012 JamieP said: Ive not made my mind up yet, i worried about breaking the stock prop tbh. Have you had any success with sorting out a new prop (not the stock one you bought) as I think I remember reading you were having a custom one made? Link to comment Share on other sites More sharing options...
scoooby slayer Posted July 5, 2012 Share Posted July 5, 2012 JamieP said: Ive not made my mind up yet, im worried about breaking the stock prop tbh. how much have you got out of a stock prop fella before twisting ? Link to comment Share on other sites More sharing options...
JamieP Posted July 5, 2012 Author Share Posted July 5, 2012 Other prop is to much of a ball ache to fit if this one fails, what with all the different studs and flanges it takes ages to fit, plus all the tools id have to bring. redline is 8300 iirc. Link to comment Share on other sites More sharing options...
Jurgen-Jm-Imports Posted July 5, 2012 Share Posted July 5, 2012 can you not make ryan bring the other pump on when you reach say 10 psi ? btw do you have a surge tank system ? i had similiar issues and switching the 2nd pump on at 10psi cured it but we will see tomorrow with lower levels of fuel witht the surge tank. Link to comment Share on other sites More sharing options...
skippyboyo1 Posted July 5, 2012 Share Posted July 5, 2012 Cool no worrys, so as Im not a boost junky what are the benefits of dropping from 1200bhp or near as for arguments sake to 1000bhp? Is it just the spool time? If so in theory could this set up be quicker on the quarter? I totaly understand the whole quarter mile time thing has gone now I'm just thinking out loud. Link to comment Share on other sites More sharing options...
Jurgen-Jm-Imports Posted July 5, 2012 Share Posted July 5, 2012 JamieP said: Other prop is to much of a ball ache to fit if this one fails, what with all the different studs and flanges it takes ages to fit, plus all the tools id have to bring. redline is 8300 iirc. we got the Evo 9 coming with tools if you need a hand mate. Link to comment Share on other sites More sharing options...
JamieP Posted July 5, 2012 Author Share Posted July 5, 2012 ajlittler said: Have you had any success with sorting out a new prop (not the stock one you bought) as I think I remember reading you were having a custom one made? Not had a chance to sort anything yet, been to busy scoooby slayer said: how much have you got out of a stock prop fella before twisting ? It broke first time i used the car in anger, and that was on the street with a 2nd to 3rd gear change, id kill a stock prop with one start at the pod. Link to comment Share on other sites More sharing options...
JamieP Posted July 5, 2012 Author Share Posted July 5, 2012 Jurgen-Jm-Imports said: we got the Evo 9 coming with tools if you need a hand mate. Got a mechanic? im not crawling round under the car mate, i really cant be arsed to break it tbh. Jurgen-Jm-Imports said: can you not make ryan bring the other pump on when you reach say 10 psi ? btw do you have a surge tank system ? i had similiar issues and switching the 2nd pump on at 10psi cured it but we will see tomorrow with lower levels of fuel witht the surge tank. Pumps are staged, Fuel system has been fine for 2 years, my money is on split pipe. Link to comment Share on other sites More sharing options...
Graham1984 Posted July 5, 2012 Share Posted July 5, 2012 JamieP said: Dont get me wrong, its still mental fast, i just wanted more boost, had 200mph down the A34 and it feels strong, spool time is not what i had hoped for You really need to go in a NA again Jp I am sure you are secretly plotting at home your next move. Link to comment Share on other sites More sharing options...
