Dim Sum Posted January 6, 2012 Share Posted January 6, 2012 Is the brake light the same bulb as the tail light? I recently changed the tail light and the dash light for bulb replacement is still showing. I noticed when I asked someone to press the brakes instead of the four lights for braking is showing, its only three and its the one I recently changed. Link to comment Share on other sites More sharing options...
mellonman Posted January 6, 2012 Share Posted January 6, 2012 did you not check the bulb you took out, it should be a double fillerment bulb. saying that you souldnt of been able to fit a single fillerment Link to comment Share on other sites More sharing options...
Lude Posted January 6, 2012 Share Posted January 6, 2012 yes its the same bulb. there are 2 filiments inside the bulb, one for lights, one for brake. this is the same on most cars Link to comment Share on other sites More sharing options...
