neo2810 Posted January 6, 2012 Share Posted January 6, 2012 I'm starting to think I have a little imp living under my bonnet who waits until I have one issue sorted and then creates another while giggling histerically and filing his nails. I really want to hurt that little fecker. Anyway, little men aside, my car has suddenly developed an issue starting up in the morning. This began around the same time (last week) that my stereo died completely (no power to it). Upon turning the key in the morning, the engine turns healthily but doesn't fire. It takes 5 or 6 prolonged attempts turning the key fully and then off again (during which it turns over healthily) before it fires to life and the runs flawlessly the rest of the day (starting fine when I leave work for home). Now I've read up on starter motor issues, battery problems, etc and still am none the wiser. The previous owner did a starter motor refurb about 2 years ago so I'd guess that makes that less likely. All my dash lights work fine, and fuses for stereo are fine and I don't think there are any indications that the battery is draining irregularly but that's only going by my incredibly naive mechanical and electrical prowess. I read a thread which tied starting problems and a dead stereo to bad battery terminal connections (which I'll check at shortly) so battery seems to be the most likely at the moment but keen to know if anyone else has had a similar issue or suggestions on the best way to inflict the maximum pain and humiliation on that damn imp! Link to comment Share on other sites More sharing options...
Dnk Posted January 6, 2012 Share Posted January 6, 2012 If the engine is turning over healthily as you put it that rules out the starter motor and battery. Link to comment Share on other sites More sharing options...
neo2810 Posted January 6, 2012 Author Share Posted January 6, 2012 If the engine is turning over healthily as you put it that rules out the starter motor and battery. Thanks Dunk.... So you think it's the imp? Link to comment Share on other sites More sharing options...
mellonman Posted January 6, 2012 Share Posted January 6, 2012 have you done the obvious first? plugs leads filters fuel/air timing/dizzy Link to comment Share on other sites More sharing options...
neo2810 Posted January 6, 2012 Author Share Posted January 6, 2012 (edited) have you done the obvious first? plugs leads filters fuel/air timing/dizzy Dear Mr Mellonman, What may seem obvious to your finely tuned mechanically experienced brain mass, may not seem so obvious to my binary tuned mechanically inept brain mass. Now I know what a plug is, but as far as actually removing them from the big, daunting mass of metal that they sit in, by first removing the other big mass of metal on top of it, no, I've not touched them for fear of either creating the most butch jigsaw puzzle in history, one which I am about as equiped to solve as a fish is to building a lego Death Star (which, by the way, is awesome!). I can see many leads under the bonnet, but no matter how much I stare at or prod them, I'm still no closer to knowing either where they go and what they do, or whether they are actually going where they are supposed to go or doing what they are supposed to do. There is a fuel filter and an air filter fitted, but again, as far as telling whether they are filtering the air and fuel as designed to do, I'm a little in the dark. And what on earth is dizzy timing? I suddenly feel so inept.... Edited January 6, 2012 by neo2810 (see edit history) Link to comment Share on other sites More sharing options...
Dnk Posted January 6, 2012 Share Posted January 6, 2012 You need to get a nice member local to you that knows a bit about the basics at least and have a look for you, or you need to find a good local garage that has a good mechanic that can have a look for you. When was it last serviced ? and what parts did it get. Link to comment Share on other sites More sharing options...
Purity14 Posted January 6, 2012 Share Posted January 6, 2012 Ignition components or fuel filter imo.. Link to comment Share on other sites More sharing options...
neo2810 Posted January 6, 2012 Author Share Posted January 6, 2012 Seriously though, the car was serviced recently, and fluids were changed. Fuel filter I assume wasn't. Air filter was fitted about 14 months ago along with a custom filter arm so shouldn't be clogged up yet. I can hear it sucking like a hoover. I've checked the distributor and made sure all the leads are tight, but have not pulled them off to check for blockages. I'm thinking that since the car runs perfectly once started and this problem only occurs in the morning, that it cant be plugs, leads or fuelling. I went out and checked the battery which is securely fitted and the terminals are connected properly. Link to comment Share on other sites More sharing options...
neo2810 Posted January 6, 2012 Author Share Posted January 6, 2012 You need to get a nice member local to you that knows a bit about the basics at least and have a look for you, or you need to find a good local garage that has a good mechanic that can have a look for you. When was it last serviced ? and what parts did it get. Lol.. sorry Dunk, my post above was tongue in cheek borne out of a slow day at work. I'm not as inept as I made out although I'm no mechanic. Jurgen's brother serviced the car last month and changed fluids and filters (not air or fuel though as far as I know). I've checked as much as I can with my limited knowledge and my skill at searching forums. I'm just looking for some additional ideas for things to check to either diagnose the problem before taking it to a pro, or at least rule out a few things. Link to comment Share on other sites More sharing options...
mellonman Posted January 6, 2012 Share Posted January 6, 2012 Dear Mr Mellonman, What may seem obvious to your finely tuned mechanically experienced brain mass, may not seem so obvious to my binary tuned mechanically inept brain mass. Now I know what a plug is, but as far as actually removing them from the big, daunting mass of metal that they sit in, by first removing the other big mass of metal on top of it, no, I've not touched them for fear of either creating the most butch jigsaw puzzle in history, one which I am about as equiped to solve as a fish is to building a lego Death Star (which, by the way, is awesome!). I can see many leads under the bonnet, but no matter how much I stare at or prod them, I'm still no closer to knowing either where they go and what they do, or whether they are actually going where they are supposed to go or doing what they are supposed to do. There is a fuel filter and an air filter fitted, but again, as far as telling whether they are filtering the air and fuel as designed to do, I'm a little in the dark. And why on earth is the timing dizzy? I suddenly feel so inept.... i love your total hosisty, or are you winding me up? i take it from your garrage that you have a n/a (non turbo) this mean that you will have a distutor cap (dizzy cap) as a rota spins inside making contacts for each spark plug to make then get power to spark, they are normally black and will have 6 leads coming from it to the spark plugs. the plugs will be in the top middle of the engine 6 in total running front to back of the engine, the timing of the car is down to the dizzy cap and can be rotated to adjust the timing. the contacts in there need to be kept clean. the fuel filter can get cloged with impureties as can the air filter. but as you have not changed nothing yet i would say start with the plugs if they was not changed when the car was serviced last. Link to comment Share on other sites More sharing options...
Purity14 Posted January 6, 2012 Share Posted January 6, 2012 Seriously though, the car was serviced recently, and fluids were changed. Fuel filter I assume wasn't. Air filter was fitted about 14 months ago along with a custom filter arm so shouldn't be clogged up yet. I can hear it sucking like a hoover. I've checked the distributor and made sure all the leads are tight, but have not pulled them off to check for blockages. I'm thinking that since the car runs perfectly once started and this problem only occurs in the morning, that it cant be plugs, leads or fuelling. I went out and checked the battery which is securely fitted and the terminals are connected properly. You should check your dizzy cap and rotor arm go take some pictures of inside the dizzy cap and we will have a look at them and see if they are worn - you only need a phillips screwdriver so its nothing too out of your depth Link to comment Share on other sites More sharing options...
Jurgen-Jm-Imports Posted January 6, 2012 Share Posted January 6, 2012 pop in next week and we can take a look, Link to comment Share on other sites More sharing options...
Dnk Posted January 6, 2012 Share Posted January 6, 2012 Cold start sensor perhaps Your problem is either ignition related or fueling related Link to comment Share on other sites More sharing options...
mellonman Posted January 6, 2012 Share Posted January 6, 2012 Lol.. sorry Dunk, my post above was tongue in cheek borne out of a slow day at work. I'm not as inept as I made out although I'm no mechanic. i knew it Link to comment Share on other sites More sharing options...
Dnk Posted January 6, 2012 Share Posted January 6, 2012 You should check your dizzy cap and rotor arm go take some pictures of inside the dizzy cap and we will have a look at them and see if they are worn - you only need a phillips screwdriver so its nothing too out of your depth What ever you do don't pull the leads off the dizzy cap or you'll be properly goosed Link to comment Share on other sites More sharing options...
Purity14 Posted January 6, 2012 Share Posted January 6, 2012 What ever you do don't pull the leads off the dizzy cap or you'll be properly goosed Just take it off and get a picture *Grins* - or label them if you dont know the firing order Link to comment Share on other sites More sharing options...
Dnk Posted January 6, 2012 Share Posted January 6, 2012 Just take it off and get a picture *Grins* - or label them if you dont know the firing order Link to comment Share on other sites More sharing options...
neo2810 Posted January 6, 2012 Author Share Posted January 6, 2012 Lol... I never take more than 1 dizzy (honestly never heard it referred to as that ) lead off at a time for that very reason! I'll give them a bit of a clean to see if that helps. New iridiums were fitted about 14 months ago so they should still have plenty of life left. I may check the easily accessibly ones to see the state of the electrodes. Link to comment Share on other sites More sharing options...
Purity14 Posted January 6, 2012 Share Posted January 6, 2012 its the 6 points inside the dizzy cap that may just need a quick clean/light sandpaper running over - it could rectify your problem instantly. Link to comment Share on other sites More sharing options...
Dnk Posted January 6, 2012 Share Posted January 6, 2012 If the caps a bit old just fit a new one with a new rotor arm, genuine Toyota aren't that much money but obviously you could get an upgraded higer performance one for half the price on ebay Link to comment Share on other sites More sharing options...
neo2810 Posted January 7, 2012 Author Share Posted January 7, 2012 (edited) Folks, just a quick update. All I did tonight was pull the leads off the dizzy and clean them one by one. Not only did my stereo start up again but it appears (I'll be able to test better tomorrow) that my 9 month aircon amnesty is also over. I'll know next week if the starting issues are fixed but I can't see it being anything else. Thanks for the suggestions all and I think I may still take an emery cloth to the inside points and rotor arm to do a proper job. I tried to get the dizzy off tonight and failed though. Took the 3x 8mm bolts off but the dizzy just sat there staring at me. It wouldn't budge and I didn't want to force it in case I missed a bolt or catch. So what's the secret? Brute force or some other trick I've missed? Edited January 7, 2012 by neo2810 (see edit history) Link to comment Share on other sites More sharing options...
dude Posted January 7, 2012 Share Posted January 7, 2012 Cold start sensor perhaps Your problem is either ignition related or fueling related Same as, once its started its warm enough not to rely on cold start for the rest of the day. Link to comment Share on other sites More sharing options...
