Higher Capacity Clutch Master Cylinder?
Guest ugp
I'm needing something to replace my stock M/C which can disperse more fluid. My slave cylinder (hilux job) has plenty of travel left, and another 3-4mm is required to disengage my clutch properly.
I've tried adjusting the rod on the pedal, which helped to some degree, but it needs just that little bit extra travel to work smoothly. If I extend the slave cylinder pin, the release bearing will be in contact with the pressure plate all the time - not good.
Does anyone have a direct swap / something else I could try?
Thanks
Ben
Perfect! Does anyone have a second hand one for sale before I go and spend some more money? :(
Darett - Looks like we shall now be singing on the double 6 for 'Pod.
Or buy a facelift 6speed slave-cinder, it has a smaller bore, so more clutch travel...
Really, now that's interesting! Can anyone else confirm they have had good results with these?
Edit:
Just read that again and realized what you meant, I'm using a Hilux slave cylinder on a custom made bell housing, so cant use the slave cyl from a TT6.
Edited by ugp (see edit history)
