Condensated front light
Suprakeith
hello my front drivers headlight got a load of water in (my fault left bulb cover off while washing car) and now the lense is full of condensation and has bin for last 10days now, Does anyone know the best way of drying headlight out without seperating the unit?
I was thinking of removing the headlight unit and putting near radiator in house over night?
Remove the bung at front of the headlight to let air circulate. Make sure its back on if its raining. Its located at front of the light :)
If you remove light and the bung, you could also remove the main beam bulb to aid in air flow.
Just a small note related to lights + condensaton & indoors - when you refit the light into the car, it may mist up ugain (as the air temperature inside the light from being in the house, will be warmer than the air outside)
But this should go after a day or so when the air temps have balanced. :)
