ellis Posted January 1, 2012 Share Posted January 1, 2012 i was lead to believe the imports are less desirable and have less horsepower? No and no! All Supras (TT) has the same 326bhp, the 280bhp gentleman's agreement was just a ruse! Good luck with bringing this back to life - be interesting to watch your progress. And welcome by the way! Quote Link to comment Share on other sites More sharing options...
mknapman77 Posted January 1, 2012 Author Share Posted January 1, 2012 yeah sorry, i didn't mean to fall into the uk / jap argument! i don't suppose you guys know if anything is the same on the mk3 celiac supra as the mk4? even if its just engine bits? Quote Link to comment Share on other sites More sharing options...
evinX Posted January 1, 2012 Share Posted January 1, 2012 Looks fairly clean to be honest, get the engine going, shouldnt be to hard, new fluids, batterys, spark plugs, do a compression test etc etc, then get her on a ramp, if the chassis is rusty, which i think it will be from sitting in a moist patch for that time then it might not be worth it, if its clean, get some new pads and discs with some new rubber and that should be all it needs, mine was more of a piggy when i got it and its going strong, welcome! Quote Link to comment Share on other sites More sharing options...
dangerous brain Posted January 1, 2012 Share Posted January 1, 2012 You may find even in the state its in that the celica supra would be of interest to someone as there is a lot of interest in restoring old skool jap motors. I imagine if you'll have any issues with the engine it'll be with the twin turbo VSV and waste gate gubbins etc as that lots all mechanical and hasn't been moved for years. You could always just sling a single on it to get around those sort of problems Quote Link to comment Share on other sites More sharing options...
SupraD06 Posted January 1, 2012 Share Posted January 1, 2012 If your unsure as to what model you have, you could always check the Vin plate on the driver wing under the boonet. Quote Link to comment Share on other sites More sharing options...
mknapman77 Posted January 1, 2012 Author Share Posted January 1, 2012 Ive checked the vin, which part dictates it being an import as opposed to a uk one? also, where is good to get parts for these like oil filters, etc? Im assuming if it is an import most normal car factors will be useless? Quote Link to comment Share on other sites More sharing options...
SupraD06 Posted January 1, 2012 Share Posted January 1, 2012 See here, http://www.mkivsupra.net/vbb/showthread.php?101452-VIN-Plate-decoder&highlight=vin+decoder And Paul, from Garagewhifbitz.co.uk on here, can sort you out with most stock parts. Quote Link to comment Share on other sites More sharing options...
peter richards Posted January 1, 2012 Share Posted January 1, 2012 (edited) i think you will find that parts will be readily available from the guys on here that break supras , and that its an import makes no difference , that was just scaremongering years ago by the dealers who quickly changed theryre minds when they realised how much they were losing out on servicing and things. Edited January 1, 2012 by peter richards (see edit history) Quote Link to comment Share on other sites More sharing options...
mknapman77 Posted January 1, 2012 Author Share Posted January 1, 2012 (edited) oops, thought the first post didn't go in! Edited January 1, 2012 by mknapman77 mistake (see edit history) Quote Link to comment Share on other sites More sharing options...
peter richards Posted January 1, 2012 Share Posted January 1, 2012 mine is an import , all i do when i need filters , i just give the shop i use my reg number and i pick it up , as for oil , ive been using valvolene for years , but there is a wide choice for you regarding oil Quote Link to comment Share on other sites More sharing options...
mknapman77 Posted January 1, 2012 Author Share Posted January 1, 2012 what grade engine oil do you recommend for it? Quote Link to comment Share on other sites More sharing options...
peter richards Posted January 1, 2012 Share Posted January 1, 2012 the valvolene i use is called VR1 5/50 Quote Link to comment Share on other sites More sharing options...
Scooter Posted January 1, 2012 Share Posted January 1, 2012 Toyota in the slyfield industrial estate aren't terrible for parts.....................you will need your chassis and model number for them though. http://www.mkiv.co.nz/ select "specs" and it will run you through the VIN number meanings...... Quote Link to comment Share on other sites More sharing options...
supraGZaerotop Posted January 2, 2012 Share Posted January 2, 2012 why in the hell would you leave a TT supra parked up in a yard/woods to rot for 8-10 years, such a massive shame, TT aswel!! Quote Link to comment Share on other sites More sharing options...
adnanshah247 Posted January 2, 2012 Share Posted January 2, 2012 poor sup! Quote Link to comment Share on other sites More sharing options...
Sheefa Posted January 2, 2012 Share Posted January 2, 2012 Best of luck although finding a TT like that means luck is on your side! Should be a beauty once brought to life Quote Link to comment Share on other sites More sharing options...
FOSTA Posted January 3, 2012 Share Posted January 3, 2012 why in the hell would you leave a TT supra parked up in a yard/woods to rot for 8-10 years, such a massive shame, TT aswel!! Just what I was thinking! I'm quite shocked! Hopfully it will be back to life soon Quote Link to comment Share on other sites More sharing options...
mknapman77 Posted January 3, 2012 Author Share Posted January 3, 2012 Well, so far so good, washed it down and hoovered it out, although gonna require some paintwork. Plugs are out, rocker covers off, given it a coat of oil and everythings moving nicely when turning over by hand, now to change the oil and filter and get it cranking to make sure ive got oil pressure! Quote Link to comment Share on other sites More sharing options...
slugger1 Posted January 3, 2012 Share Posted January 3, 2012 basically the guy who owned it rented some offices on my uncles land. there is this car, and a very rotten celica supra there too, so he was obviously a fan! from what i can gather he ended up with some issues, then in rehab, so thats where they've sat ever since! I'm in aldershot, so not too far away at all, ill be sure to give you a shout if i need anything cheers! There are quite a few of us in the Aldershot/Farnborough area so when it's back on the road you will have get involved in one of the local meets. Good luck in the meantime! Quote Link to comment Share on other sites More sharing options...
mknapman77 Posted January 3, 2012 Author Share Posted January 3, 2012 Cheers mate, its all turning over now, oils circulating , just gotta clear the fuel out, put some fresh in and hopefully it will spring to life! Quote Link to comment Share on other sites More sharing options...
mknapman77 Posted January 3, 2012 Author Share Posted January 3, 2012 hi all, ive run into my first problem! i seem to have engine fault codes 14, which i think is an ignition circuit problem, although i do have a spark, and the 2nd is 78, which is fuel pump related. I do however have some kind of aftermarket alarm/immobiliser, and im thinking that possibly all of this could stem from not being able to disarm that. obviously i will be trying to take that out of the system tomorrow (i think its some kind of toad alarm) just wondering if anyone else had any ideas? another question i have is where is the fuel pump? I currently have no workshop manuals, as they still havent turned up from the people i ordered them from. thanks for any advice Quote Link to comment Share on other sites More sharing options...
mknapman77 Posted January 3, 2012 Author Share Posted January 3, 2012 also, does anyone know how to disable any standard immobilisers on it? Quote Link to comment Share on other sites More sharing options...
Shane Posted January 3, 2012 Share Posted January 3, 2012 Hi mate and welcome. In the diagnostic port, link Fp and B+ with a short piece of wire, when you switch the ignition on you should be able to hear the pump,its in the tank by the way. If you can hear the pump then you should have fuel pressure up at the injector rail and it may start , but you will still need to look at why you have to feed a permanent feed to the pump. If you cant hear anything then report back and we can go a bit further into it. Quote Link to comment Share on other sites More sharing options...
mknapman77 Posted January 3, 2012 Author Share Posted January 3, 2012 i actually tried that and i couldnt hear the pump, is it common for the pump to break? Quote Link to comment Share on other sites More sharing options...
TubbyTwo Posted January 4, 2012 Share Posted January 4, 2012 This is going to be a good thread Subscribed and good luck!! Quote Link to comment Share on other sites More sharing options...
