Mattsson mkiv RHD-LHD and NA-T Convension
mattsson
  • Replies 136
@vanil: Piter if you get any other LHD swap kit, but from 98 let me know!!!
@mattsson: Great work mate! Wiring is always fun, otherwise it wouldn't be interesting :D
Mate at this time I have metal firewall (it's the same) and wiring harness from 97 y. LHD, climate control from 97 y. if U intrested.
  • 2 weeks later...
  • 4 weeks later...
  • 1 month later...
GOOD UPDATES MATE¬!!! :)
did you make the intake setup yourself?
yes im building the intake myself
its not the best way to make it but its an easy way to do it if it dont flow even i will find it out with the individual egt sensors in manifold.
the hvac i used the jspec wiering but it shold be the same as the us LHD lom
but the pinout is diffrent in the control panel. i cut the US contacts and collor matched it to my J spec loom 1 wier wasent used in the us loom think it was green ....
it works but ther is somthing that aint right i thik becaus if i choose defrost i get air on the flor and wise versa... will look at it later or if you find out pls let me know
Hi
i will let you know when i work on it,.
im waiting to get the car home from the painter and then ill start the electric fun part :)
  • 3 weeks later...
i haw got hold off a hiace W59 that im going to run this summer hopfully will hold toghether if i lower the boost to 1bar
dont hawe money for a V160 and dont hawe time to make a Bmw getrag fit the car.
will hawe to be a winter project ....
  • 3 weeks later...
