JamieP Posted December 29, 2011 Author Share Posted December 29, 2011 Its got a different end welded on, think this one is billet instead of cast, ive go prop loops going on both ends this time chris. Link to comment Share on other sites More sharing options...
Josh Posted December 29, 2011 Share Posted December 29, 2011 What's different about this new one to the older uprated unit? I would have thought they'd use bigger U/J's and bigger tube OD for the hollow part of the shaft. It'd scare the heck out of me, having seen what a flailing prop can do if it decides to lathe through the floorpan, or dig into the road surface. There's a thread showing when he had a prop hoop made up IIRC. Link to comment Share on other sites More sharing options...
TubbyTwo Posted December 30, 2011 Share Posted December 30, 2011 Good work, you certainly break things in style! Link to comment Share on other sites More sharing options...
Chris Wilson Posted December 30, 2011 Share Posted December 30, 2011 Its got a different end welded on, think this one is billet instead of cast, ive go prop loops going on both ends this time chris. It's not the yoke that's failed though, the tube diameter, material or wall thickness is inadequate, and is crippling under the torque loadings. My Skyline prop I had made is probably 1/3 bigger on tube diameter, which makes a huge difference to torque transmission and shock load capacity, and I am running lots less torque through hard 265 section rear tyres. Are you sure this new one is going to be safe? Exploding flywheels and snapped props REALLY worry me. Take care, you are using up your nine lives uncomfortably quickly Link to comment Share on other sites More sharing options...
JamieP Posted December 30, 2011 Author Share Posted December 30, 2011 (edited) It's not the yoke that's failed though, the tube diameter, material or wall thickness is inadequate, and is crippling under the torque loadings. My Skyline prop I had made is probably 1/3 bigger on tube diameter, which makes a huge difference to torque transmission and shock load capacity, and I am running lots less torque through hard 265 section rear tyres. Are you sure this new one is going to be safe? Exploding flywheels and snapped props REALLY worry me. Take care, you are using up your nine lives uncomfortably quickly The one that failed in the first post is a stock prop chris, yes that one failed because of the small tube, the one above about is 3.5" and wont fail there, i twisted the spline on the old uprated one a very slight amount, this new one is supposed to be even stronger. Edited December 30, 2011 by JamieP (see edit history) Link to comment Share on other sites More sharing options...
pistonbroke Posted December 30, 2011 Share Posted December 30, 2011 Crazy mate, at least it's not as bad as when your red one let go and ripped a hole in the floor Link to comment Share on other sites More sharing options...
JamieP Posted December 31, 2011 Author Share Posted December 31, 2011 This was the only damage aside from the heat sheild, lucky boy. Im going to drop it down to my fabricators monday to repair, might also get a straight through rear box made while its there. Anyone has a prop heat sheild going spare im after one. Link to comment Share on other sites More sharing options...
fastcar Posted December 31, 2011 Share Posted December 31, 2011 Very lucky could have been a lot worse! Link to comment Share on other sites More sharing options...
Chris Wilson Posted December 31, 2011 Share Posted December 31, 2011 I have a prop heat shield, make me a bid to pack it up and send it next week if you like, not looking for much. Link to comment Share on other sites More sharing options...
JamieP Posted December 31, 2011 Author Share Posted December 31, 2011 I have a prop heat shield, make me a bid to pack it up and send it next week if you like, not looking for much. You know what i was just thinking Chris, maybe i should give my damaged one to my fabricator and get him to make me one out of 4 or 5 mm plate and put some extra bolts in? worth it or waste of time? Link to comment Share on other sites More sharing options...
JamieP Posted January 6, 2012 Author Share Posted January 6, 2012 It's all back together and I've just been for a blast I had the DSS flange modded so it located on the diff the same as the stock one does, I didn't like the idea of all that stress just on the bolts. Link to comment Share on other sites More sharing options...
Rob_Mitchell Posted January 6, 2012 Share Posted January 6, 2012 Glad its all back together mate. You got anything else planned for her? You had that tow eye long? Link to comment Share on other sites More sharing options...
JamieP Posted January 6, 2012 Author Share Posted January 6, 2012 Had it ages, should be picking up my new bonnet in a day or two. Link to comment Share on other sites More sharing options...
Luxluc Posted January 6, 2012 Share Posted January 6, 2012 Good to know you're back on the road Jamie Link to comment Share on other sites More sharing options...
Rob_Mitchell Posted January 6, 2012 Share Posted January 6, 2012 Had it ages, should be picking up my new bonnet in a day or two. ... Pm me if he can do another. jealous? me? NEVER!! Link to comment Share on other sites More sharing options...
mellonman Posted January 6, 2012 Share Posted January 6, 2012 glad to hear your back on the road i dont surpose your old rubber coupling was any good? Link to comment Share on other sites More sharing options...
JamieP Posted January 6, 2012 Author Share Posted January 6, 2012 ... Pm me if he can do another. jealous? me? NEVER!! He can do more, you would be better just buying the carbon hump from him and fitting yourself no? Link to comment Share on other sites More sharing options...
Rob_Mitchell Posted January 6, 2012 Share Posted January 6, 2012 He can do more, you would be better just buying the carbon hump from him and fitting yourself no? I will call him. Very much looking forward to seeing yours. Link to comment Share on other sites More sharing options...
wewsupra Posted January 6, 2012 Share Posted January 6, 2012 the camera footage is good mate Link to comment Share on other sites More sharing options...
Rob_Mitchell Posted January 6, 2012 Share Posted January 6, 2012 He going to call me.. he has taken a full mould of yours JP so doing FULL CARBON badboys Link to comment Share on other sites More sharing options...
Josh Posted January 6, 2012 Share Posted January 6, 2012 He going to call me.. he has taken a full mould of yours JP so doing FULL CARBON badboys Beast! Looking good, Jamie. In for the pics of the new bonnet fitted. Link to comment Share on other sites More sharing options...
JamieP Posted January 6, 2012 Author Share Posted January 6, 2012 glad to hear your back on the road i dont surpose your old rubber coupling was any good? Yeah ive got a couple, make me an offer if you want one. Link to comment Share on other sites More sharing options...
JamieP Posted January 6, 2012 Author Share Posted January 6, 2012 He going to call me.. he has taken a full mould of yours JP so doing FULL CARBON badboys Yeah, they will be a lot of money, Nur products are worth every penny though IMO. Link to comment Share on other sites More sharing options...
Rob_Mitchell Posted January 6, 2012 Share Posted January 6, 2012 Yeah, they will be a lot of money, Nur products are worth every penny though IMO. Yeah still cheaper than what i bought Link to comment Share on other sites More sharing options...
JamieP Posted January 6, 2012 Author Share Posted January 6, 2012 How much did he say for full carbon Nur-luck? Link to comment Share on other sites More sharing options...
