Bonnet
p00t
  • Replies 58
Guys,
Check out the tech articles on http://www.mkiv.com - there is one called 'European hood scoop install' that covers alot of the things you need to know about doing this.
As for if having the vent actually working is of any use to you J-spec guys - I guess not as it was not fitted as standard. I think this might be because you have ceramic turbos - less susceptable to heat than the steel UK ones perhaps?
Good luck - I wouldn't fancy cutting a big hole in my bonnet - but then I've already got one!
