Jap and UK spec caliper pistons in stainless steel.
Chris Wilson
Finally in stock on the shelf, I now offer stainless steel caliper pistons for both the front and rear Jap spec calipers. These are more prone to seizure than the UK calipers, so I am hoping these will prove popular for when you need to overhaul a J-Spec caliper. They are bigger and use a lot more material than the UK pistons, so are slightly dearer. I do front pistons at £22 plus VAT each and rears at £24 plus VAT each. I will be stocking the seal kits, too, at a better price than from a Toyota dealer. If you don't fancy rebuilding your own units I can do them at a labour cost of £52 plus VAT for fronts and £40 plus VAT for rears, assuming they aren't rusted out or seized rock solid.. I would ask you speak to me before removing them off the car, as I need them sent with the pistons almost out, and the best way to do this is with them still on the vehicle using hydraulic pressure from the brake pedal. I can't powder coat them, only paint them in Kephos, in satin black, or in standard high temp aerosol colours. Let me know if you need pistons for Jap or UK spec calipers, or your own units rebuilding.. Thanks. PLEASE USE E-MAIL ONLY!
